What do you think about not responding of the sensor after resetting or unplugging enp8266 nodemcu v3?
engkhaledeisa
Hi how are you ....i bought a new esp8266 (also I bought logic level shifter and 74125 IC) and built the project from the beginning as the schematics in the beginning it works fine the rgb ring lights up and the sensor responds and performs the interruption function BUT when I reset the esp nodemcu v3 or unplug the replug the usb to pc the sensor didnot respond .....do yoou think that because I still didnot connect the logic level shifter or the ic between the ring and the esp ?
- Screenshot (5).png (225.07 KiB) Viewed 3533 times
