PIN input without connection
Arisen
Postby Arisen » Sat May 11, 2024 4:34 pm
I've been trying to do some basic stuff on ESP32 DevKit v1 but then run into some issues. Input pin reads values even if it's not connected to anything. It doesn't matter which pin i use (I've tried 18,15,12,27,35 and 25) it's still the same. I used this code to test it out:
void setup() {
  Serial.begin(115200);
  pinMode(27,INPUT);
  pinMode(23,OUTPUT);
  pinMode(19,OUTPUT);
  digitalWrite(19,HIGH);
void loop() {
  Serial.println(digitalRead(27));
  delay(100);
  if (digitalRead(27)==1){
    digitalWrite(23,HIGH);
  digitalWrite(23,LOW);
Re: PIN input without connection
Postby Sprite » Sun May 12, 2024 3:23 am
Yeah, that's to be expected. An unconnected input pin is high-impedance and will pick up whatever EMC is around to determine its value.
Arisen
Postby Arisen » Sun May 12, 2024 9:21 am
How can I fix that? I've been thinking about using INPUT_PULLDOWN instead of INPUT but haven't tried that yet.
(That behaviour also happens if i connect a sensor there. It randomly gets a signal without ever recieving one)
Postby Sprite » Mon May 13, 2024 6:44 am
You can use a pullup or pulldown, either external or internal, to pull the pin to a known level. If you connect a sensor, you need to check what output the sensor has: if it's open-drain, you'll need a pullup for it to work.
Users browsing this forum: DuckDuckGo [Bot] and 1 guest
