ESP IDF A2DP Changing Sample Rate
jimmyvongjv
Postby jimmyvongjv » Fri May 17, 2024 6:39 pm
I am currently working on a project that has a ESP32 connected to a pair of bluetooth earbuds through A2DP. Right now, it seems that my bluetooth earbuds are using a sample rate of 88.2 kHz which I don't want because that requires my music to take up a lot of space. Is there a way for me to change this so that its streaming with a sample rate of 44.1 kHz or anything lower than 88.2 kHz?
liaifat85
Re: ESP IDF A2DP Changing Sample Rate
Postby liaifat85 » Sat May 18, 2024 10:29 am
The Bluetooth earbuds should support the sample rate you are setting. Do you know the specs of your earbuds?
Users browsing this forum: PerplexityBot, Qwantbot and 8 guests
