I have GPIO_NUM_10 (ADC1 CH 9) connected to a 1S LiPo battery via a voltage divider circuit in order to monitor battery voltage. When I call analogRead() within the main program (ie loop()), everything works exactly as expected. However, I have been wanting to move my battery monitoring code to a background process that executes periodically, so I moved my code to a background process using xTaskCreatePinnedToCore(), which I have used for several other process on this same board with no issues. However, the value that gets returned from analogRead() when called from this background process is highly unstable, returning garbage data. When I call analogRead() from both loop() and my background process, the value that comes from loop() is stable and accurate whereas the value that comes from the background process is essentially noise. I was not able to find mention of this issue anywhere and would greatly appreciate it if anyone could share any insight regarding this strange behaviors. Here is the code in question:
void background_process_battery(void *parameter)
TickType_t xLastWakeTime;
const TickType_t xFrequency = pdMS_TO_TICKS(BATTERY_REFRESH);
xLastWakeTime = xTaskGetTickCount();
for (;;) // a FreeRTOS task should never return
int raw_read = analogRead(BAT_V_SENSE_PIN);
float computed_voltage = raw_read * (3.3 / 4096.0) * 1.03 + 0.80; // Seems to best match actual vbat
log_v("raw_read: %d, computed_value: %f", raw_read, computed_voltage);
vTaskDelayUntil(&xLastWakeTime, xFrequency); // non-blocking delay
}Code: Select all
background_process_battery, /* Function to implement the task */
"background_process_battery", /* Name of the task */
10000, /* Stack size in words */
NULL, /* Task input parameter */
0, /* Priority of the task */
&TaskHandle_background_process_battery, /* Task handle */
0); /* Core where the task should run */
