Hello, I want to know if there is a way to use the nimble controller stack with ESP-IDF.
Currently, in the menu-config, we can only select the host stack, but not for the controller stack. However, I'm already aware that ESP32 architecture has the same ESP controller used for two different host stacks. As Nimble stack is open source, I am currently doing my research based on Nimble stack and finding ways to get optimized and efficient throughput for ble. One of the ways is to remove CRC and verify its throughput.
Please also suggest if there is any way to alter the packet using the built-in ESP Controller itself.
I appreciate any help you can provide.
Regards,
Meghana
Nimble controller stack usage in ESP-IDF
Re: Nimble controller stack usage in ESP-IDF
@rahult-github could you please support me here? I understand you are a nimble developer, so please help It's important.
I appreciate any esp controller developer @espressif to consider with high importance.
Thanks in advance, hoping for some help.
ESP chipsets have their own controller. So for Nimble ( or bluedroid ) only the host part of upstream mynewt-nimble code is used. The nimble controller part is not enabled / compiled in ESP-IDF .
Thanks for the response @irahul. It'd be really helpful if you could suggest any way to test the nimble controller using any possible methods. Or if you are aware of how to remove CRC inclusion and verification in the packet sent using the ESP controller code itself, that'll be helpful too for my research work. Hoping for a positive response.ESP chipsets have their own controller. So for Nimble ( or bluedroid ) only the host part of upstream mynewt-nimble code is used. The nimble controller part is not enabled / compiled in ESP-IDF .
Thanks again.
Users browsing this forum: Bing [Bot], ChatGPT-User, PerplexityBot and 2 guests
