Cannot install USB host driver after installing i2c Driver in ESP32-S3
DxPian
Postby DxPian » Tue May 21, 2024 2:15 am
Code: Untitled.txt Select all
In ESP32-S3, Installing USB host driver fails once I2C driver was installed already.
If I uninstall I2C driver, USB host driver successfully installed.
Bellow is a brief sample code to reproduce the issue.
Error code = 261(ESP_ERR_NOT_FOUND)
Code: Untitled.c Select all
void init_i2c(){
int i2c_master_port = 1;
i2c_config_t conf = {0,};
conf.mode = I2C_MODE_MASTER;
conf.sda_io_num = I2C_MASTER_SDA_IO;
conf.sda_pullup_en = GPIO_PULLUP_ENABLE;
conf.scl_io_num = I2C_MASTER_SCL_IO;
conf.scl_pullup_en = GPIO_PULLUP_ENABLE;
conf.master.clk_speed = 10000;
i2c_param_config(i2c_master_port, &conf);
i2c_driver_install(i2c_master_port, conf.mode,
I2C_MASTER_RX_BUF_DISABLE,
I2C_MASTER_TX_BUF_DISABLE, 0);
void init_usb(){
esp_msc_host_config_t msc_host = {
.base_path = "/usb",
.host_driver_config = {
.create_backround_task = true,
.task_priority = 5,
.stack_size = 4096
.vfs_fat_mount_config = {
.format_if_mount_failed = false,
.max_files = 3,
.allocation_unit_size = 1024,
.host_config = {
.intr_flags = ESP_INTR_FLAG_LEVEL1,
err = usb_host_install(&config->host_config);
if(err != ESP_OK){
ESP_LOGE(TAG, "Failed to install USB host driver: %d", err); // err=261(ESP_ERR_NOT_FOUND)
return err;
return ESP_OK;
void app_main(void)
esp_log_level_set("*", ESP_LOG_DEBUG) ;
init_i2c();
init_usb(); // failed here
leonardo.costa
Re: Cannot install USB host driver after installing i2c Driver in ESP32-S3
Postby leonardo.costa » Fri Jun 07, 2024 9:36 am
i had the same problem and i resolved it using ESP_INTER_FLAG_LEVEL2 as shown below:
const usb_host_config_t host_config = {
.intr_flags = ESP_INTR_FLAG_LEVEL2,
Leo
Users browsing this forum: Baidu [Spider], PerplexityBot and 4 guests
