The docs mention that I2S0 can be routed directly to the internal analog-to-digital converter (ADC) and digital-to-analog converter (DAC). In other words, ADC and DAC peripherals can read or write continuously via I2S0 DMA. As they are not actual communication modes, the I2S driver does not implement them. The driver does not implement the LCD mode either.
I want to record audio using the ADC and i2s. This used to be possible in the earlier versions of the idf used to have a way to enable ADC mode and I have found examples that do this using an older version of the idf and it seems fairly straightforward here.
I am new to esp-idf, can someone show me how I would implement this, or steps that I can take to do this. Thanks
How do I use the ADC mode for i2s is esp-idf v5.2.2?
Re: How do I use the ADC mode for i2s is esp-idf v5.2.2?
I've looked into this but how would I configure the i2s drivers. Will i2s_read() start reading from this buffer? How do I make multiple buffers using the continuous mode driver. Some code would help. Thanks
You do not have to do anything with I2S if you use that driver; it handles the fact that on the ESP32 the data transfer happens to go through I2S entirely for you.
Hi @ESP_Sprite,You do not have to do anything with I2S if you use that driver; it handles the fact that on the ESP32 the data transfer happens to go through I2S entirely for you.
Nice to see a fellow Tweaker here
If I start i2s first and then enable the adc continuous example I get:
i2s_platform: i2s controller 0 has been occupied by i2s_driverCode: Select all
W (13156) i2s_platform: i2s controller 0 has been occupied by adc
E (13166) i2s_common: i2s0 might be occupied by other componentRe: How do I use the ADC mode for i2s is esp-idf v5.2.2?
There's no need to start I2S in ESP-IDF V5. The continuous ADC driver should take care of setting up I2S by itself.
Ok thanks for clarifying. But then how do I set up the pin numbers and sample rate configuration etc for i2s? Sorry if this is a stupid question.
Also, I was manually setting up i2s and continuous adc for testing purposes to get something working. My actual goal is to use the bluetooth classic hfp_hf example which sets up i2s under the hood. I'm getting the feeling I can't have the continuous adc and hfp_hf both trying to automagically set up i2s for me?
the only problem whit this aproch is the fact that this driver by default drops every 11th and 12th samples on the esp32You can use this driver for that.
So I found a more perfomant workaround. Useing the legacy i2s api it is posible to continusly sample without the droped samples but it only supports 1 channel. The simplest solution to this is to manualy set the pattern table registers (APB_SARADC_SAR1_PATT_TAB1 for example can be found as APB_CTRL_APB_SARADC_SAR1_PATT_TAB1_REG in soc/apb_ctrl_reg.h) and then change the length of the pattern table in APB_SARADC_CTRL_REG this can be easily accesed with SYSCON.saradc_ctrl.sar1_patt_len from soc/syscon_struct.h the layout of those variables can be found in the esp32 technical reference manual. page 640 and for the pattern table registers and page 656 for APB_SARADC_CTRL_REG
Users browsing this forum: PerplexityBot, PetalBot and 2 guests
