I'm reaching out in desperation as I've been struggling with an issue while trying to flash my ESP32. I've followed multiple troubleshooting guides and tried various solutions, but nothing seems to work.
The Issue:
Whenever I try to flash the ESP32 using esptool.py, I encounter the following errors:
invalid header: 0x00000000
ets Jul 29 2019 12:21:46
waiting for download
Sketch uses 252585 bytes (19%) of program storage space. Maximum is 1310720 bytes.
Global variables use 17000 bytes (5%) of dynamic memory, leaving 310680 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.6
Serial port COM3
Connecting......
TypeError: argument of type 'NoneType' is not iterable
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
Configuring flash size...
Failed uploading: uploading error: exit status 1
Connections:
Red (VCC) to 3V3 (Pin 2)
Black (GND) to GND (Pin 1 or Pin 15)
Green (TXD) to RXD0 (GPIO3, Pin 34)
White (RXD) to TXD0 (GPIO1, Pin 35)
GPIO0 (Pin 25) to GND for boot mode
Entering Bootloader Mode:
Press and hold the BOOT button (GPIO0 low) while pressing and releasing the EN (Enable) button.
Driver Installation:
Installed CP210x Universal Windows Driver v11.3.0.
Flashing Process:
Attempted to erase flash and flash firmware using:bashCopy codeesptool.py --port COM3 erase_flash esptool.py --port COM3 --baud 115200 write_flash -z 0x1000 your_firmware.bin
Power Supply:
Used a powered USB hub to ensure sufficient power.
Added a Capacitor:
Connected a 10 µF Tantalum Capacitor (16V) between the EN pin and GND.
This is the board: https://www.optimusdigital.ro/ro/placi- ... th-42.html
Datasheet: https://www.optimusdigital.ro/ro/index. ... hment=1479
