So I have my own functions: my_log_vprintf(), my_printf(), my_fputs() which capture the output and send it to tcp, or to serial console, or disregard, depending on the value of console_state variable.
int my_log_vprintf(const char *fmt, va_list arguments)
if(console_state == CONSOLE_ON)
return vprintf(fmt, arguments);
else if(console_state == CONSOLE_TCP)
char buf[1024];
vsnprintf(buf, sizeof(buf) - 1, fmt, arguments);
return tcp_log_message(buf);
return 0;
void my_printf(char *format, ...)
char buf[1024];
va_list args;
va_start( args, format );
vsnprintf( buf, sizeof(buf) - 1, format, args );
va_end( args );
puts(buf);
//puts(buf);
void my_fputs(char *buf, FILE *f)
puts(buf);
//puts(buf);
}Here is my tcp_log.c which sends the buffer to the server running ncat
static int tcp_log_enable;
static struct sockaddr_in srv_addr;
static TaskHandle_t tcp_log_task_handle;
static QueueHandle_t tcp_log_evt_queue;
static void tcp_log_task(void *pvParameters);
#define MSG_QUEUE_SIZE 20
int tcp_log_init(void)
int ret = ESP_FAIL;
tcp_log_enable = 0;
int sendsock;
struct hostent *hent = NULL;
if(!tcp_log_enable)
bzero((char *) &srv_addr, sizeof(srv_addr));
sendsock = socket(AF_INET, SOCK_STREAM, 0);
if(sendsock >= 0)
hent = gethostbyname(LOG_SERVER);
if(hent)
srv_addr.sin_port = htons(LOG_PORT);
srv_addr.sin_family = AF_INET;
srv_addr.sin_addr.s_addr = *(u_long *) hent->h_addr_list[0];
tcp_log_evt_queue = xQueueCreate(MSG_QUEUE_SIZE, 1024);
if(tcp_log_evt_queue)
if(xTaskCreate(tcp_log_task, "TCP_log_task", 4096, NULL, USER_TASK_PRIORITY, &tcp_log_task_handle) == pdPASS)
ret = ESP_OK;
tcp_log_enable = 1;
else
vQueueDelete(tcp_log_evt_queue);
close(sendsock);
return ret;
int tcp_log_message(char *message)
char buf[1024];
//if !tcp_log_enable try to init first
if(!tcp_log_enable)
tcp_log_init();
if(tcp_log_enable)
strcpy(buf, USER_MQTT);
strcat(buf, ":: ");
strncat(buf, message, 1023 - 2 - strlen(USER_MQTT) );
xQueueSend(tcp_log_evt_queue, buf, ( TickType_t ) 10);
return 0;
char buf[1024];
while(1)
xQueueReceive(tcp_log_evt_queue, buf, portMAX_DELAY);
int sendsock = socket(AF_INET, SOCK_STREAM, 0);
if(buf[strlen(buf) - 1] != '\n')
strcat(buf, "\n");
int written = 0;
if (sendsock >= 0)
if(connect(sendsock, (struct sockaddr *)&srv_addr, sizeof(srv_addr)) >= 0)
while(written < strlen(buf))
int sent = send(sendsock, buf + written, strlen(buf), 0);
if (sent < 0)
break;
else
written += sent;
close(sendsock);
}Code: Select all
static int free_mem(int argc, char **argv)
my_printf("%d", esp_get_free_heap_size());
return 0;
}If console_state == CONSOLE_ON, which means serial console, there is no impact on memory.
It looks either I’m doing something wrong or it’s something related to memory management.
Any suggestions?
