Bluetooth connection of PS4 controller and RemoteXY interface
BWV999
Postby BWV999 » Fri Jun 28, 2024 4:17 pm
I am trying to connect a PS4 controller and display an interface on a phone using the RemoteXY library. Both function properly on separate sketches, but if i combine them, the connection to one device or the other is not possible. The order in which i call PS4.begin("C0:49:EF:E7:CD:5E"); or RemoteXY_Init (); determines wich one is working. I suspect some conflict in the BT serial configuration, but the initialisation code is in the libraries. I have trouble navigating the library functions to determine the origin of the problem. Here are both libraries in question:
https://github.com/RemoteXY/RemoteXY-Arduino-library
https://github.com/xman4242/PS4-ESP32
Here is my arduino code
Code: Untitled.txt Select all
#include <PS4Controller.h>
#include <ps4.h>
#include <ps4_int.h>
// RemoteXY include library //
// you can enable debug logging to Serial at 115200
//#define REMOTEXY__DEBUGLOG
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__ESP32CORE_BLUETOOTH
#include <BluetoothSerial.h>
// RemoteXY connection settings
#define REMOTEXY_BLUETOOTH_NAME "RemoteXY"
#include <RemoteXY.h>
// RemoteXY GUI configuration
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] = // 55 bytes
{ 255,12,0,11,0,48,0,17,0,0,0,31,1,106,200,1,1,3,0,2,
18,36,44,22,0,2,26,31,31,79,78,0,79,70,70,0,7,51,77,40,
10,36,2,26,2,11,67,6,77,40,10,4,2,26,11 };
// this structure defines all the variables and events of your control interface
struct {
// input variables
uint8_t switch_01; // =1 if switch ON and =0 if OFF
char edit_01[11]; // string UTF8 end zero
// output variables
char text_01[11]; // string UTF8 end zero
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
const byte pin_sortie_relais_alimentation = 12;
byte dernier_etat_switch_01 = 0;
void setup()
Serial.begin(115200);
PS4.begin("C0:49:EF:E7:CD:5E"); //ESP
RemoteXY_Init ();
pinMode(pin_sortie_relais_alimentation, OUTPUT);
digitalWrite(pin_sortie_relais_alimentation, RemoteXY.switch_01);
Serial.println("adresse MAC BT");
uint8_t baseMac[6];
// Get the MAC address of the Bluetooth interface
esp_read_mac(baseMac, ESP_MAC_BT);
Serial.print("Bluetooth MAC: ");
for (int i = 0; i < 5; i++) {
Serial.printf("%02X:", baseMac[i]);
Serial.printf("%02X\n", baseMac[5]);
Serial.println("");
void loop()
RemoteXY_Handler ();
if (RemoteXY.switch_01 != dernier_etat_switch_01){
dernier_etat_switch_01 = RemoteXY.switch_01;
//Serial.println("Relais : " + switch_01);
itoa(millis(), RemoteXY.text_01, 10);
//if (PS4.Circle()) Serial.println("Circle Button");
Users browsing this forum: Baidu [Spider], ChatGPT-User, Qwantbot and 3 guests
