ESP32 c3 wroom02 flashes but monitor shows invalid header: 0xffffff0f error
russianbearx
Postby russianbearx » Sat Jul 13, 2024 10:50 am
I want to run the esp32c3 wroom 02 card with at commands with the docklight application, but I get the error "invalid header 0xffffff". can you help?
Code: Untitled.py Select all
Re: ESP32 c3 wroom02 flashes but monitor shows invalid header: 0xffffff0f error
Postby Sprite » Sun Jul 14, 2024 5:27 am
Likely something went wrong with flashing the firmware. Can you tell how you flashed it? Are you sure you selected the correct firmware for the chip? (E.g. esp32 vs esp32-c3)
Harsha
Re: ESP32 c3 wroom02 flashing issue
Postby Harsha » Thu Jul 18, 2024 1:32 pm
<t>Hi everyone,<br/>
<br/>
I've been researching the ESP32-C3 flashing circuit and have designed a basic circuit for flashing the ESP32-C3 SMD board. However, when I try to flash the basic blink example code, I encounter the following error: "COM5 failed to connect: Failed to connect to Espressif device: No serial data received."<br/>
<br/>
I've also attached the PCB design for reference.<br/>
<br/>
Any advice on how to resolve this issue would be greatly appreciated.</t>
esp_flash_circuit.pdf
(817 Bytes) Downloaded 123 times
Users browsing this forum: Bing [Bot], PerplexityBot and 2 guests
