Private (or "3rd party") Component Registry?
gamename
Postby gamename » Sun Jul 14, 2024 7:06 pm
Has anyone succeeded in creating their own registry? If so, how? I've been going over the docs and it isn't clear if that's possible. Basically, I want to have my own collection of components to pull with `idf.py add-submodule`.
Or, should I just create component repos and add them as submodules manually?
Thanks,
-T
unclewalrus
Re: Private (or "3rd party") Component Registry?
Postby unclewalrus » Sat Jan 10, 2026 8:59 pm
I have not ever been able to identify such a possibility.
git submodules is probably the best alternative, and not a terrible one honesty.
Ideally Espressif could publish the source code from the registry with an option to self-host; but I don't really see much in the source code of the toolchain that would make that an easy process...
nopnop2002
Contact:
Postby nopnop2002 » Sun Jan 11, 2026 1:59 pm
You can include the GitHub repository as managed_components in your project.
Create an idf_component.yml like this in your project.
When you build a projects esp-idf will automaticly fetch repository to managed_components dir and link with your code.
$ cat main/idf_component.yml
## IDF Component Manager Manifest File
dependencies:
  Molorius/esp32-websocket:
    git: https://github.com/Molorius/esp32-websocket
