ESP32 FREQUENCY METER - 2 CHANNELS - WORKING !!
As promised, I managed to fix the interference problem between the interrupts of the two Pulse Counters 0 and 1.
The solution was to disable the Pulse Counter interrupt right after the complete count using the "
pcnt_isr_unregister" function.
After printing the value of frequency 0, I enabled the interrupt of Pulse Counter 1 (function "
pcnt_isr_register").
And after printing the value of frequency 1, I enabled the interrupt of Pulse Counter 0. It worked!
Every second, a counter counts the pulses and calculates the frequency. Everything is controlled with the 1-second One-shot Timers.
To test the frequency counter, you can use the signals from both oscillators (initial values for Osc 0 = 10,000 Hz and Osc 1 = 20,000 Hz).
Connect the oscillator output to the frequency counter channel input.
To change the oscillator frequencies, enter one value at a time (without commas) in the Arduino IDE serial console (115200 bps).
The first value will be used in Oscillator 0 and the second value will be used in Oscillator 1. Very simple.
There is only one more challenge left - when the CH0 input channel is disconnected, the frequency value varies different from 0 Hz.
But the CH1 channel, when disconnected presents a frequency of 0 Hz (which is the expected value).
Connect the CH0 input channel to an oscillator circuit and the frequency will be measured accurately!
I implemented a variable for calibrating measurements (offset)- calibrator => calibrator of frequency reading (may be + or - integer numbers).
Use resistors R1 and R2 to equalize the voltage level on the I2C bus to 3.3V used in ESP32.
I didn't understand how to use the "
pcnt_isr_unregister" function. And with the help of
ChatGPT Artificial Intelligence, everything became clear.
- ChatGPT ESP32 unregister ISR.JPG (49.6 KiB) Viewed 9722 times
If you are in doubt about the I2C address of your I2C LCD module, use the I2C scanner.
ESP32 - I2C Scanner using Arduino IDE
viewtopic.php?f=18&t=4742
Add this library LCD-I2C using the Arduino IDE library manager
https://github.com/hasenradball/LCD-I2C
Github Project: (use "Arduino Code/ESP32_FrequencyMeter_2CH_V3.ino")
https://github.com/Gustavomurta/ESP32_f ... _Meter_2CH
ESP32 API references used in this project:
https://docs.espressif.com/projects/esp ... /ledc.html
https://docs.espressif.com/projects/esp ... timer.html
https://docs.espressif.com/projects/esp ... /pcnt.html
ESP32 Frequency Meter / 2 Channel - Version 3
ESP32 DevKit + I2C PCF8574 LCD
Arduino IDE 2.3.2 / ESP32 Arduino V 3.02
Gustavo Murta e Rui Viana august/2020 - 2024/07/30
// ESP32 Frequency Meter / 2 Channel - Version 3
// ESP32 DevKit + I2C PCF8574 LCD
// Arduino IDE 2.3.2 / ESP32 Arduino V 3.02
// Gustavo Murta e Rui Viana august/2020 - 2024/07/30
// https://blog.eletrogate.com/esp32-frequencimetro-de-precisao
// https://www.esp32.com/viewtopic.php?f=19&t=17018
// References:
// https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/ledc.html
// https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/esp_timer.html
// https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/pcnt.html
// LCD I2C SDA - GPIO_21
// LCD I2C SCL - GPIO_22
#include "stdio.h" // Library STDIO
#include "driver/ledc.h" // Library ESP32 LEDC
#include "driver/pcnt.h" // Library ESP32 PCNT
#include "soc/pcnt_struct.h" // Library ESP32 PCNT
#include "esp32/rom/gpio.h" // Library ESP32 GPIO
#include <LCD-I2C.h> // Library LCD with PCF8574
LCD_I2C lcd(0x3F, 16, 2); // Instance LCD I2C - address 0x3F
#define PCNT_COUNT_UNIT_0 PCNT_UNIT_0 // Set Pulse Counter Unit - 0
#define PCNT_COUNT_CHANNEL_0 PCNT_CHANNEL_0 // Set Pulse Counter channel - 0
#define PCNT_INPUT_SIG_IO_0 GPIO_NUM_34 // Set Pulse Counter input - Freq Meter Input GPIO 34
#define PCNT_INPUT_CTRL_IO_0 GPIO_NUM_35 // Set Pulse Counter Control GPIO pin - HIGH = count up, LOW = count down
#define OUTPUT_CONTROL_GPIO_0 GPIO_NUM_32 // Timer output control port - GPIO_32
#define PCNT_COUNT_UNIT_1 PCNT_UNIT_1 // Set Pulse Counter Unit - 1
#define PCNT_COUNT_CHANNEL_1 PCNT_CHANNEL_1 // Set Pulse Counter channel - 0
#define PCNT_INPUT_SIG_IO_1 GPIO_NUM_25 // Set Pulse Counter input - Freq Meter Input GPIO 25
#define PCNT_INPUT_CTRL_IO_1 GPIO_NUM_26 // Set Pulse Counter Control GPIO pin - HIGH = count up, LOW = count down
#define OUTPUT_CONTROL_GPIO_1 GPIO_NUM_27 // Timer output control port - GPIO_27
#define LEDC_HS_CH0_GPIO GPIO_NUM_33 // LEDC output - pulse generator 0 - GPIO_33
#define LEDC_HS_CH1_GPIO GPIO_NUM_14 // LEDC output - pulse generator 1 - GPIO_14
#define PCNT_H_LIM_VAL overflow // Overflow of Pulse Counter
uint32_t overflow = 32000; // Max Pulse Counter value 32000 - limit 32767
uint32_t sample_time = 1000000; // Sample time of 1 second to count pulses
uint calibrator = 1; // calibrator of frequency reading (may be + or - integer numbers)
bool flag_0 = false; // Flag to enable print frequency reading
int16_t pulses_0 = 0; // Pulse Counter value
uint32_t multPulses_0 = 0; // Number of PCNT counter overflows
float frequency_0 = 0; // frequency value
bool pressEnter = false; //
bool flag_1 = true; // Flag to enable print frequency reading
int16_t pulses_1 = 0; // Pulse Counter value
uint32_t multPulses_1 = 0; // Number of PCNT counter overflows
float frequency_1 = 0; // frequency value
uint32_t osc_freq_0 = 10000; // Oscillator frequency - initial 10000 Hz (may be 1 Hz to 40 MHz)
uint32_t mDuty_0 = 0; // Duty cycle value
uint32_t resolution_0 = 0; // Resolution value of Oscillator
uint32_t osc_freq_1 = 20000; // Oscillator frequency - initial 20000 Hz (may be 1 Hz to 40 MHz)
uint32_t mDuty_1 = 0; // Duty cycle value
uint32_t resolution_1 = 0; // Resolution value of Oscillator
char buf_0[32]; // Buffer 0
char buf_1[32]; // Buffer 1
esp_timer_create_args_t timer_args_0; // Create an esp_timer instance
esp_timer_handle_t timer_handle_0; // Create an single timer
esp_timer_create_args_t timer_args_1; // Create an esp_timer instance
esp_timer_handle_t timer_handle_1; // Create an single timer
pcnt_isr_handle_t pcnt_intr_handle_0;
pcnt_isr_handle_t pcnt_intr_handle_1;
void setup() {
Serial.begin(115200); // Serial Console Arduino 115200 Bps
Serial.println(); // Print line
Serial.println(" Enter the Frequency - 1 to 40 MHz - First Osc 0 / Second Osc 1"); // Console print
Serial.println(" Oscillators have some accuracy limitations "); // Console print
lcd.begin();
lcd.display();
lcd.backlight();
lcd.setCursor(0, 0); // Set cursor position - column and row
lcd.print("F0:"); // LCD print
lcd.setCursor(0, 1); // Set cursor position - column and row
lcd.print("F1:"); // LCD print
init_frequencyMeter(); // Initialize Frequency Meter
void init_osc_freq_0() // Initialize Oscillator to test Freq Meter
resolution_0 = (log(80000000 / osc_freq_0) / log(2)) / 2; // Calc of resolution of Oscillator
if (resolution_0 < 1) resolution_0 = 1; // set min resolution
// Serial.println(resolution); // Print
mDuty_0 = (pow(2, resolution_0)) / 2; // Calc of Duty Cycle 50% of the pulse
// Serial.println(mDuty); // Print
ledc_timer_config_t ledc_timer = {}; // LEDC timer config instance
ledc_timer.duty_resolution = ledc_timer_bit_t(resolution_0); // Set resolution
ledc_timer.freq_hz = osc_freq_0; // Set Oscillator frequency
ledc_timer.speed_mode = LEDC_HIGH_SPEED_MODE; // Set high speed mode
ledc_timer.timer_num = LEDC_TIMER_0; // Set LEDC timer index - 0
ledc_timer_config(&ledc_timer); // Set LEDC Timer config
ledc_channel_config_t ledc_channel = {}; // LEDC Channel config instance
ledc_channel.channel = LEDC_CHANNEL_0; // Set HS Channel - 0
ledc_channel.duty = mDuty_0; // Set Duty Cycle 50%
ledc_channel.gpio_num = LEDC_HS_CH0_GPIO; // LEDC Oscillator output GPIO 33
ledc_channel.intr_type = LEDC_INTR_DISABLE; // LEDC Fade interrupt disable
ledc_channel.speed_mode = LEDC_HIGH_SPEED_MODE; // Set LEDC high speed mode
ledc_channel.timer_sel = LEDC_TIMER_0; // Set timer source of channel - 0
ledc_channel_config(&ledc_channel); // Config LEDC channel
void init_osc_freq_1() // Initialize Oscillator to test Freq Meter
resolution_1 = (log(80000000 / osc_freq_1) / log(2)) / 2; // Calc of resolution of Oscillator
if (resolution_1 < 1) resolution_1 = 1; // set min resolution
mDuty_1 = (pow(2, resolution_1)) / 2; // Calc of Duty Cycle 50% of the pulse
ledc_timer.duty_resolution = ledc_timer_bit_t(resolution_1); // Set resolution
ledc_timer.freq_hz = osc_freq_1; // Set Oscillator frequency
ledc_timer.timer_num = LEDC_TIMER_1; // Set LEDC timer index - 0
ledc_channel.channel = LEDC_CHANNEL_1; // Set HS Channel - 0
ledc_channel.duty = mDuty_1; // Set Duty Cycle 50%
ledc_channel.gpio_num = LEDC_HS_CH1_GPIO; // LEDC Oscillator output GPIO 14
ledc_channel.timer_sel = LEDC_TIMER_1; // Set timer source of channel - 0
static void IRAM_ATTR pcnt_intr_handler_0(void *arg) // Counting overflow pulses
multPulses_0++; // increment Overflow counter
PCNT.int_clr.val = BIT(PCNT_COUNT_UNIT_0); // Clear Pulse Counter interrupt bit
pcnt_counter_resume(PCNT_COUNT_UNIT_0); // Resume PCNT unit - starts count
static void IRAM_ATTR pcnt_intr_handler_1(void *arg) // Counting overflow pulses
multPulses_1++; // increment Overflow counter
PCNT.int_clr.val = BIT(PCNT_COUNT_UNIT_1); // Clear Pulse Counter interrupt bit
pcnt_counter_resume(PCNT_COUNT_UNIT_1); // Resume PCNT unit - starts count
void init_PCNT_0(void) // Initialize and run PCNT 0 unit
gpio_pad_select_gpio(OUTPUT_CONTROL_GPIO_0); // Set GPIO pad
gpio_set_direction(OUTPUT_CONTROL_GPIO_0, GPIO_MODE_OUTPUT); // Set GPIO 32 as Timer output
timer_args_0.callback = read_PCNT_0; // Function to call when the timer expires - stop counter
esp_timer_create(&timer_args_0, &timer_handle_0); // Create esp-timer instance / single timer
pcnt_config_t pcnt_config_0 = {}; // PCNT unit instance
pcnt_config_0.pulse_gpio_num = PCNT_INPUT_SIG_IO_0; // Pulse input GPIO 34 - Freq Meter Input
pcnt_config_0.ctrl_gpio_num = PCNT_INPUT_CTRL_IO_0; // Pulse Count Control signal - input GPIO 35
pcnt_config_0.unit = PCNT_COUNT_UNIT_0; // Pulse Count Unit PCNT - 0
pcnt_config_0.channel = PCNT_COUNT_CHANNEL_0; // Pulse Count Unit Channel - 0
pcnt_config_0.counter_h_lim = PCNT_H_LIM_VAL; // Maximum counter value - 32000 pulses
pcnt_config_0.pos_mode = PCNT_COUNT_INC; // PCNT positive edge count mode - inc
pcnt_config_0.neg_mode = PCNT_COUNT_INC; // PCNT negative edge count mode - inc
pcnt_config_0.lctrl_mode = PCNT_MODE_DISABLE; // PCNT low control mode - disable
pcnt_config_0.hctrl_mode = PCNT_MODE_KEEP; // PCNT high control mode - won't change counter mode
pcnt_unit_config(&pcnt_config_0); // Initialize PCNT unit
pcnt_event_enable(PCNT_COUNT_UNIT_0, PCNT_EVT_H_LIM); // Enable event to watch - max count
pcnt_intr_enable(PCNT_COUNT_UNIT_0); // Enable interrupts for PCNT unit
void init_PCNT_1(void) // Initialize and run PCNT 1 unit
gpio_pad_select_gpio(OUTPUT_CONTROL_GPIO_1); // Set GPIO pad
gpio_set_direction(OUTPUT_CONTROL_GPIO_1, GPIO_MODE_OUTPUT); // Set GPIO 27 as Timer output
timer_args_1.callback = read_PCNT_1; // Function to call when the timer expires - stop counter
esp_timer_create(&timer_args_1, &timer_handle_1); // Create esp-timer instance / single timer
pcnt_config_t pcnt_config_1 = {}; // PCNT unit instance
pcnt_config_1.pulse_gpio_num = PCNT_INPUT_SIG_IO_1; // Pulse input GPIO 25 - Freq Meter Input
pcnt_config_1.ctrl_gpio_num = PCNT_INPUT_CTRL_IO_1; // Pulse Count Control signal - input GPIO 26
pcnt_config_1.unit = PCNT_COUNT_UNIT_1; // Pulse Count Unit PCNT - 1
pcnt_config_1.channel = PCNT_COUNT_CHANNEL_1; // Pulse Count Unit Channel - 1
pcnt_config_1.counter_h_lim = PCNT_H_LIM_VAL; // Maximum counter value - 32000 pulses
pcnt_config_1.pos_mode = PCNT_COUNT_INC; // PCNT positive edge count mode - inc
pcnt_config_1.neg_mode = PCNT_COUNT_INC; // PCNT negative edge count mode - inc
pcnt_config_1.lctrl_mode = PCNT_MODE_DISABLE; // PCNT low control mode - disable
pcnt_config_1.hctrl_mode = PCNT_MODE_KEEP; // PCNT high control mode - won't change counter mode
pcnt_unit_config(&pcnt_config_1); // Initialize PCNT unit
pcnt_event_enable(PCNT_COUNT_UNIT_1, PCNT_EVT_H_LIM); // Enable event to watch - max count
pcnt_intr_enable(PCNT_COUNT_UNIT_1); // Enable interrupts for PCNT unit
void read_PCNT_0(void *p) // Read Pulse Counter 0 - timeout callback
pcnt_get_counter_value(PCNT_COUNT_UNIT_0, &pulses_0); // Read Pulse Counter value
gpio_set_level(OUTPUT_CONTROL_GPIO_0, 0); // Stop counter - GPIO 32 - output control LOW
flag_0 = true; // Change flag 0 to enable print
void read_PCNT_1(void *p) // Read Pulse Counter 1 - timeout callback
pcnt_get_counter_value(PCNT_COUNT_UNIT_1, &pulses_1); // Read Pulse Counter value
gpio_set_level(OUTPUT_CONTROL_GPIO_1, 0); // Stop counter - GPIO 27 - output control LOW
flag_1 = true; // Change flag 1 to enable print
void init_frequencyMeter() {
init_osc_freq_0(); // Config and Initialize Oscillator 0
init_osc_freq_1(); // Config and Initialize Oscillator 1
init_PCNT_0(); // Config and Initialize PCNT 0 unit
init_PCNT_1(); // Config and Initialize PCNT 1 unit
char *ultos_recursive(unsigned long val, char *s, unsigned radix, int pos) // Format an unsigned long (32 bits) into a string
int c;
if (val >= radix)
s = ultos_recursive(val / radix, s, radix, pos + 1);
c = val % radix;
c += (c < 10 ? '0' : 'a' - 10);
*s++ = c;
if (pos % 3 == 0) *s++ = ','; // decimal separator
return s;
char *ltos(long val, char *s, int radix) // Format an long (32 bits) into a string
if (radix < 2 || radix > 36) {
s[0] = 0;
} else {
char *p = s;
if (radix == 10 && val < 0) {
val = -val;
*p++ = '-';
p = ultos_recursive(val, p, radix, 0) - 1;
*p = 0;
return s;
void loop() {
if (flag_0 == true) { // If count 0 has ended
flag_0 = false; // Change flag to enable count
pcnt_isr_unregister(pcnt_intr_handle_0); // Unregister PCNT interrupt handler 0
frequency_0 = (pulses_0 + (multPulses_0 * (overflow + calibrator))) / 2; // Calculation of frequency
printf("Frequency CH0: %s", (ltos(frequency_0, buf_0, 10))); // Print frequency with commas
printf(" Hz \n"); // Print unity Hz
lcd.setCursor(3, 0); // Set cursor position - column and row
lcd.print(" "); // Clear Field
lcd.print((ltos(frequency_0, buf_0, 10))); // LCD print frequency
lcd.print(" Hz"); // LCD print unity Hz
multPulses_1 = 0; // Clear overflow counter 1
pcnt_counter_clear(PCNT_COUNT_UNIT_1); // Clear Pulse Counter 1
esp_timer_start_once(timer_handle_1, sample_time); // Start High resolution timer (1 sec)
gpio_set_level(OUTPUT_CONTROL_GPIO_1, 1); // Set enable PCNT count 1 - GPIO 27
pcnt_isr_register(pcnt_intr_handler_1, NULL, 0, &pcnt_intr_handle_1); // Setup Register ISR handler
if (flag_1 == true) { // If count 1 has ended
flag_1 = false; // Change flag to enable count
pcnt_isr_unregister(pcnt_intr_handle_1); // Unregister PCNT interrupt handler 1
frequency_1 = (pulses_1 + (multPulses_1 * (overflow + calibrator))) / 2; // Calculation of frequency
printf("Frequency CH1: %s", (ltos(frequency_1, buf_1, 10))); // Print frequency with commas
lcd.setCursor(3, 1); // Set cursor position - column and row
lcd.print(" "); // Clear field
lcd.print((ltos(frequency_1, buf_1, 10))); // LCD print frequency
multPulses_0 = 0; // Clear overflow counter 0
pcnt_counter_clear(PCNT_COUNT_UNIT_0); // Clear Pulse Counter 0 pcnt_unit_clear_count
esp_timer_start_once(timer_handle_0, sample_time); // Start High resolution timer (1 sec)
gpio_set_level(OUTPUT_CONTROL_GPIO_0, 1); // Set enable PCNT count 0 - GPIO 32
pcnt_isr_register(pcnt_intr_handler_0, NULL, 0, &pcnt_intr_handle_0); // Setup Register ISR handler
// Input of frequency value => First Osc 0 - Second Osc 1
String inputString = ""; // clear temporary string
while (Serial.available()) {
char inChar = (char)Serial.read(); // Reads a byte on the console
inputString += inChar; // Add char to string
if (inChar == '\n') // If press enter
if (pressEnter == false) {
osc_freq_0 = inputString.toInt(); // Converts String into integer value
Serial.print("Osc. 0 = ");
Serial.println(osc_freq_0); // Print Oscillator 0
init_osc_freq_0(); // reconfigure ledc function - oscillator 0
inputString = ""; // Clear string
} else {
osc_freq_1 = inputString.toInt(); // Converts String into integer value
Serial.print("Osc. 1 = ");
Serial.println(osc_freq_1); // Print Oscillator 0
init_osc_freq_1(); // reconfigure ledc function - oscillator 1
pressEnter = !pressEnter; // invert pressEnter
Arduino Console - COM14 - 115200 baud
ets Jul 29 2019 12:21:46
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1448
load:0x40078000,len:14844
ho 0 tail 12 room 4
load:0x40080400,len:4
load:0x40080404,len:3356
entry 0x4008059c
E (156) esp_cor�յ�}���͡� Core dump data check failed:
Calculated checksum='cbb3a019'
Image chec
Frequency CH1: 0 Hz
Frequency CH0: 10,000 Hz
Frequency CH1: 20,000 Hz
Frequency CH1: 20,001 Hz
Schematic to download:
- ESP32_Frequency_Meter_2CH.JPG (102.66 KiB) Viewed 9722 times
Open these images in another page in your browser to view at a better size.
