I use combine esp-rainmaker and esp-matter.
When building the ESP-Rainmaker matter_light example, the project builds correctly. However, when enabling ESP Insights in menuconfig, the build fails with the following CMake error:
esp insights project commit: cfdd71e cmake error at /home/dnk067/esp/esp-idf/tools/cmake/component.cmake:381 (__component_get_property): __component_get_property function invoked with incorrect arguments for function named: __component_get_property call stack (most recent call first): /home/dnk067/esp/esp-matter/connectedhomeip/connectedhomeip/config/esp32/components/chip/cmakelists.txt:471 (idf_component_get_property)
This is my Cmake file,
set(EXTRA_COMPONENT_DIRS
"${MATTER_SDK_PATH}/config/esp32/components"
"${ESP_MATTER_PATH}/components"
"${ESP_MATTER_PATH}/device_hal/device"
"${ESP_MATTER_PATH}/examples/common"
"${RMAKER_PATH}/examples/common/app_insights"
"${RMAKER_PATH}/components"
${extra_components_dirs_append})
Any guidance on how to handle or resolve this issue would be greatly appreciated.
Thanks!
CMake Error When Enabling ESP Insights in ESP-Rainmaker Matter Light Example Build
Rahul_Baraiya
