Propagating Values from Project Kconfig to Component Kconfig
gamename
Postby gamename » Sun Jul 28, 2024 10:37 pm
What is the best way, or is there a way, to set a value in a parent Kconfig menu and have it available in a subordinate component Kconfig? In other words, how can I set a variable in the parent Kconfig and have it available in the component Kconfig?
For example, I want the WIFI_HOSTNAME "Foo" to be set in "some_component" as well as the parent. One approach would be:
config WIFI_HOSTNAME
    string "WiFi Hostname"
    default "Foo"
    help
        Set the WiFi hostname for the project.
# Source the "some_component" Kconfig
source "${COMPONENT_KCONFIGS_DIR}/some_component/Kconfig"
Then, in "some_component", I could do this. But it doesn't work:
config GECL_OTA_MANAGER_WIFI_HOSTNAME
    string "WiFi Hostname this component"
    default "${WIFI_HOSTNAME}"   # <---- DOES NOT WORK
    help
        Set the WiFi hostname in the component.
endif
What's the answer, or is this just not possible?
TIA,
-T
MicroController
Re: Propagating Values from Project Kconfig to Component Kconfig
Postby MicroController » Mon Jul 29, 2024 3:56 am
Try
default WIFI_HOSTNAME
Users browsing this forum: Google [Bot], Qwantbot and 1 guest
