What kind of solder is used inside Espressif's ESP modules? What is the melting point?
When we solder (or remove) by a heating table, at what temperature will the solder inside the module not melt?
What temperature should I use to melt ESP module (WROOM) to PCB, while not melting the solder inside module?
Re: What temperature should I use to melt ESP module (WROOM) to PCB, while not melting the solder inside module?
that info is in the data sheet
Datasheet says 250℃ peak temperature. But I'm still confused (I'm new to hardware design). Does it mean that the solder inside module won't melt at 250℃, and, let's say we're trying to remove one, at that temperature we can pull the ESP module off the PCB (fast and don't have to keep it horizental) without any inside damage ?
Users browsing this forum: PetalBot and 5 guests
