USB examples for ESP32-H2-MINI
thepurplepig
Postby thepurplepig » Sun Aug 04, 2024 1:04 pm
Hi, my first post.
I have a ESP32-H2-MINI hooked up up on USB port.
I can program in the HWCDC_Events example out the 'ESP32' folder, that works fine but if I try any of the other USB examples like USBVendor out of the 'USB' folder, nothing happens. Perhaps there is something in the examples configuration that I need to change, or maybe they are not for this device?
I am looking for more USB examples that will work with ESP32-H2. I would specifically like to set the module up as a custom HID device for one project and as a mouse for another project.
Any pointers appreciated, thank you.
Re: USB examples for ESP32-H2-MINI
Postby Sprite » Mon Aug 05, 2024 2:49 am
The -H2 does not have the USB-OTG controller you'd need for those examples; it only has a fixed-function USB-serial-JTAG controller.
thepurplepig
Postby thepurplepig » Mon Aug 05, 2024 9:00 am
Ok thanks, makes sense now.
Does that mean there are no modules that have a fully fledged that USB small enough go into a USB dongle? WROOM is too wide.
Postby Sprite » Tue Aug 06, 2024 9:16 am
The other chips also have -mini variants of their modules, e.g. the esp-s3-mini-1. Possibly those are small enough.
lbernstone
Postby lbernstone » Tue Aug 06, 2024 5:28 pm
The 8684/8685 modules have some small and different form factors that may work for you, although this means that they have lower production volumes and availability.
https://www.espressif.com/en/products/modules
https://products.espressif.com/#/product-selector
thepurplepig
Postby thepurplepig » Tue Aug 06, 2024 6:35 pm
Thanks all,
What I really need is a mini format but with both Bluetooth Classic and either USB CDC or USB.
Looks like I'm out of luck.
Postby Sprite » Wed Aug 07, 2024 3:39 am
Those also don't have USB OTG.
Is that S3 module still too large?
thepurplepig
Postby thepurplepig » Wed Aug 07, 2024 8:16 am
Does the S3 do bluetooth classic as well? I thought not but if it does that ticks all boxes.
*just checked seems not. So there are no BTC capable modules with USB OTG and vice versa.
However I could make do with USB HWCDC and not fully fledged OTG, but there is no USB CDC in the part selector.
If I select 'USB OTG' in the selector, are parts with HWCDC also listed?
If not, are there any parts with USHWCDC and Bluetooth Classic?
Postby Sprite » Thu Aug 08, 2024 1:25 am
Nope. Only chip that does BT Classic is the 'original' ESP32, and that does not have USB of any sort.
Users browsing this forum: Qwantbot and 5 guests
