ESP32S3
jahan1
ESP32S3
Postby jahan1 » Tue Aug 13, 2024 5:13 pm
Can anyone check the below schematics of ESP32-S3-WROOM-1-N16R8, I am using windows 11 and unable to detect the usb com port to program the controller. I tried to follow the schematic of a board of ESP32S3R8N8.
Attached is my schematics. I used CH334F and CH340K. Drivers are installed as well.
Screenshot 2024-08-13 181145.png (223.16 KiB) Viewed 2226 times
JBS_ABRIZ
Re: ESP32S3
Postby JBS_ABRIZ » Wed Aug 14, 2024 2:43 pm
Where is the boot button? A lot of times the IO 0 is used to but the ESP32-S3 into boot mode then Windows will recognize the USB port as a COM port. Here can find an example: https://learn.adafruit.com/assets/112329
jahan1
Re: ESP32S3
Postby jahan1 » Sat Aug 17, 2024 10:18 pm
Thank you for the reply.
GPI0 is connected with GND via push button. I highlighted it with red in the schematics. I tested the board on multiple PCs, multiple wire, still getting unknown USB driver.
Anyone please help.
Screenshot 2024-08-13 181145.png (230.28 KiB) Viewed 1944 times
Re: ESP32S3
Postby Sprite » Sun Aug 18, 2024 6:22 am
Also note that the programming is done via a serial-to-USB converter chip: you should be able to find that regardless of the ESP32 state.
In general, I'd try to figure out which chips *are* detected: you should see both the USB hub chip as well as the USB-serial converter. I have no idea how to check for those under Windows, but the system log under Linux (dmesg) may give you more info when you plug the board in.
Users browsing this forum: ChatGPT-User, Google [Bot], Semrush [Bot] and 1 guest
