ESP-Mesh - Multiple messages transmitted
NielsPost
Postby NielsPost » Tue Mar 28, 2023 9:09 am
I am using ESP-IDF with esp_mesh to synchronise time between multiple ESP32 Nodes.
Most of this works fine, except I am noticing the following happening:
- Node A sends message to Node B, but gets an ESP_ERR_MESH_TIMEOUT from the esp_mesh_send call
- Node B does receive this message
- Going forward after the timeout, every message that node A sends is received by other nodes twice
The issue seems to be on the transmit side. When I reboot every other (receiving) node, and let them reconnect, they still receive double messages.
The issue also seems to stack. So after 3 of these timeouts, messages are received 4 times instead of 1.
I am using the following code to transmit:
  mesh_data_t dataType{
      .data = (uint8_t*) &m_tcpSendBuffer,
      .size = static_cast<uint16_t>(data.size() + sizeof(PacketHeader_t)),
      .proto = MESH_PROTO_BIN,
      .tos = MESH_TOS_P2P};
      auto sendResult = esp_mesh_send(&espDestination, &dataType, MESH_DATA_P2P, nullptr, 0);
and the following code to receive
	  mesh_data_t dataInfo{
      		.data = (uint8_t*) &m_tcpReceiveBuffer,
      		.size = static_cast<uint16_t>(TCP_PACKET_SIZE)
  	int flag = 0;
 	auto receiveResult = esp_mesh_recv(&sourceMacAddress, &dataInfo, 0, &flag, nullptr, 0);
From logging on the sender side, I can confirm that esp_mesh_send is only called once.
Is there any parameter I should be looking at to help prevent this issue? Or should I be clearing some buffer when an error occurs?
Sidenote is that I am using ESP_Mesh ESP_now simultaneously in this project. I expect this to work, but perhaps I am missing something?
greg-solargik
Re: ESP-Mesh - Multiple messages transmitted
Postby greg-solargik » Thu Aug 15, 2024 9:43 am
We are seeing this issue as well. Have you found a resolution to this?
NielsPost
Postby NielsPost » Thu Aug 15, 2024 2:49 pm
Hi Greg,
I'm afraid that I haven't found a solution for this problem. Due to this, and other issues that came up during development, we decided to drop the mesh library completely.
For our project, I wrote a replacement which uses ESP-NOW to manually form a mesh network with the required properties. This was enough in our case, but such a solution might be inappropriate or insufficient for your use case.
Regards,
Niels
Users browsing this forum: Baidu [Spider], Barkrowler, meta-externalagent, PerplexityBot and 4 guests
