ESP32H2 usb boot after powron
gaysin1111
Postby gaysin1111 » Mon Sep 02, 2024 5:22 pm
when power is supplied (smoothly) from a laboratory power source, for example, it goes to the USB bootloader. I will say right away, the connection diagram according to the datasheet is similar to DEV BOARD schematocs. IO8 IO9 are pulled up through 10 kOhm to Vcc, EN through 10 kOhm + 1 μF.
At the same time, if you pull the reset after powering up, the μF starts. After which the bootloader goes to UART normally, is flashed, works.
Re: ESP32H2 usb boot after powron
Postby Sprite » Tue Sep 03, 2024 2:41 am
Are you sure you don't have a capacitor on IO9, e.g. to 'debounce' a button that might be on there?
gaysin1111
Postby gaysin1111 » Tue Sep 03, 2024 4:48 am
here is my schematics for ESP32H2 tests.
Снимок экрана 2024-09-03 113755.jpg (10.77 KiB) Viewed 6456 times
Снимок экрана 2024-09-03 094703.jpg (123.34 KiB) Viewed 6505 times
