ESP32-C3 Custom PCB Design Issue - Device Not Working
fawazapp
Postby fawazapp » Thu Sep 12, 2024 7:26 am
Hi all,
I’ve designed a custom PCB for the ESP32-C3 SoC following all the steps outlined in the design guide document. However, the device is still not working, and I’m unable to pinpoint the problem.
I’ve attached the schematic and PCB layout images for reference.
Would appreciate any guidance on what might be causing the issue or what steps I can take to troubleshoot this further.
SCH
Screenshot 2024-09-12 at 10.15.58 AM.png (331.29 KiB) Viewed 2936 times
PCB
Screenshot 2024-09-12 at 10.17.09 AM.png (250.48 KiB) Viewed 2936 times
Thanks in advance for your help!
Re: ESP32-C3 Custom PCB Design Issue - Device Not Working
Postby Sprite » Thu Sep 12, 2024 1:50 pm
That is about the most useless diagnostics you can post here. In what way specifically is it not working? What did you already measure / try?
fawazapp
Postby fawazapp » Thu Sep 12, 2024 7:07 pm
Power Supply: I’ve confirmed that the ESP32-C3 is receiving 3.3V at its VDD pin using a multimeter.
Boot Mode: I’ve checked the boot and enable pins and ensured they’re correctly connected.
Postby Sprite » Fri Sep 13, 2024 12:17 am
