ESP32s2 and S3 SHA-256 comparison failed
_Rens_
Postby _Rens_ » Fri Jul 15, 2022 9:23 am
Since trying out the arduinoOta and uploading a different not yet working usb update bin file i keep getting the SHA-256 comparison failed error when booting in the console log.
Also previous working usb examples stop working, i tried to erase the flash and burn the bootloader but none of that worked.
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x43c
load:0x403c9700,len:0xbec
load:0x403cc700,len:0x2a3c
SHA-256 comparison failed:
Calculated: 3611f330726ad4edf64f62982b0568332a5800bc59425cab90be5379db92c108
Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
Attempting to boot anyway...
entry 0x403c98d8
Running blinking
Running partition type 0 subtype 16 (offset 0x00010000)
Running firmware version: heads/idf-release/v4.4-0-gd4572
device speed: USB_SPEED_FULL, device address: 1, max ep_ctrl size: 8, config: 1
Guru Meditation Error: Core  0 panic'ed (Unhandled debug exception).
Debug exception reason: Stack canary watchpoint triggered (async)
Core  0 register dump:
PC      : 0x4037cfaf  PS      : 0x00060136  A0      : 0x8037c88b  A1      : 0x3fce3520
A2      : 0x3fc92eb0  A3      : 0xb33fffff  A4      : 0x0000abab  A5      : 0x00060123
A6      : 0x00060123  A7      : 0x0000cdcd  A8      : 0xb33fffff  A9      : 0xffffffff
A10     : 0x0000003f  A11     : 0x3fce3e98  A12     : 0x3fc94e28  A13     : 0x00060323
A14     : 0x02c92eb0  A15     : 0x00ffffff  SAR     : 0x00000004  EXCCAUSE: 0x00000001
EXCVADDR: 0x00000000  LBEG    : 0x400556d5  LEND    : 0x400556e5  LCOUNT  : 0xfffffffe
Backtrace:0x4037cfac:0x3fce35200x4037c888:0x3fce3560 0x4037b1c7:0x3fce3580 0x4037b270:0x3fce35c0 0x403788a1:0x3fce35e0 0x4037898d:0x3fce3610 0x4200de22:0x3fce3630 0x4200ce79:0x3fce3650 0x4200c8d9:0x3fce3670 0x4201e4a9:0x3fce3690 0x4201c4be:0x3fce36b0 0x4201c546:0x3fce36d0 0x4201d179:0x3fce3700 0x4202bedd:0x3fce3730 0x4202546f:0x3fce3750 0x4201ddb5:0x3fce3a60 0x42002316:0x3fce3ab0 0x42001cde:0x3fce3ae0 0x420021ab:0x3fce3b60 0x4201347f:0x3fce3b80 0x420020dd:0x3fce3bb0
ELF file SHA256: 0000000000000000
with every new code that i upload i keep getting this same error.
Update:
The crash was not related to the sha 256 comparison failed. Cause of the crash was due to the usb pendrive.
shcho@hunslab.com
Re: ESP32s2 and S3 SHA-256 comparison failed
Postby shcho@hunslab.com » Fri Sep 20, 2024 12:55 am
1. SHA256 Checksum Error is occurred when you check "Serial flasher config -> [ ] Detect flash size when flashing bootloader"
This option set 'CONFIG_ESPTOOLPY_HEADER_FLASHSIZE_UPDATE' in sdkconfig
please read help for this option.
2. In my case
SHA256 checksum error does not affect my application.
Users browsing this forum: Applebot, Bing [Bot] and 2 guests
