I am trying to get the BLE example "examples/bluetooth/nimble/bleprph" running on a ESP32c6. Background is that in my project I need extended advertising (manufacturer data). When I compile and run the example with no configuration changed (extended advertising is on by default), I can't find the device on my phone (using nRF Connect app). Just as an experiment, I disabled extended advertising. Then, the device is visible on my phone.
Bellow is the output from the monitor (I had to add a vTaskDelay(500 / portTICK_PERIOD_MS); as the very first statement in app_main to get over Waiting for the device to reconnect in the monitor. See https://esp32.com/viewtopic.php?t=21505):
$ idf.py -p /dev/ttyACM0 flash monitor
Executing action: flash
Running ninja in directory /home/esp32/tmp/esp-idf/examples/bluetooth/nimble/bleprph/build
Executing "ninja flash"...
[1/5] cd /home/esp32/tmp/esp-idf/examples/bluetooth/nimble/bleprph/build/esp-idf/esptool_py &...rtition-table.bin /home/esp32/tmp/esp-idf/examples/bluetooth/nimble/bleprph/build/bleprph.bin
bleprph.bin binary size 0x9f790 bytes. Smallest app partition is 0x100000 bytes. 0x60870 bytes (38%) free.
[1/1] cd /home/esp32/tmp/esp-idf/examples/bluetooth/nimble/bleprph/build/bootloader/esp-idf/e...0x0 /home/esp32/tmp/esp-idf/examples/bluetooth/nimble/bleprph/build/bootloader/bootloader.bin
Bootloader binary size 0x5500 bytes. 0x2b00 bytes (34%) free.
[4/5] cd /home/esp32/esp/esp-idf/components/esptool_py && /usr/bin/cmake -D IDF_PATH=/home/es...h/nimble/bleprph/build -P /home/esp32/esp/esp-idf/components/esptool_py/run_serial_tool.cmake
esptool.py --chip esp32c6 -p /dev/ttyACM0 -b 460800 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 80m --flash_size 2MB 0x0 bootloader/bootloader.bin 0x10000 bleprph.bin 0x8000 partition_table/partition-table.bin
esptool.py v4.8.dev5
Serial port /dev/ttyACM0
Connecting...
Chip is ESP32-C6 (QFN40) (revision v0.0)
Features: WiFi 6, BT 5, IEEE802.15.4
Crystal is 40MHz
MAC: 40:4c:ca:ff:fe:57:d4:90
BASE MAC: 40:4c:ca:57:d4:90
MAC_EXT: ff:fe
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x000affff...
SHA digest in image updated
Compressed 21760 bytes to 13120...
Writing at 0x00000000... (100 %)
Wrote 21760 bytes (13120 compressed) at 0x00000000 in 0.4 seconds (effective 435.4 kbit/s)...
Hash of data verified.
Compressed 653200 bytes to 382729...
Writing at 0x000ac0cc... (100 %)
Wrote 653200 bytes (382729 compressed) at 0x00010000 in 5.1 seconds (effective 1020.5 kbit/s)...
Compressed 3072 bytes to 103...
Wrote 3072 bytes (103 compressed) at 0x00008000 in 0.0 seconds (effective 508.7 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Executing action: monitor
Running idf_monitor in directory /home/esp32/tmp/esp-idf/examples/bluetooth/nimble/bleprph
Executing "/home/esp32/.espressif/python_env/idf5.3_py3.12_env/bin/python /home/esp32/esp/esp-idf/tools/idf_monitor.py -p /dev/ttyACM0 -b 115200 --toolchain-prefix riscv32-esp-elf- --target esp32c6 --revision 0 --decode-panic backtrace /home/esp32/tmp/esp-idf/examples/bluetooth/nimble/bleprph/build/bleprph.elf -m '/home/esp32/.espressif/python_env/idf5.3_py3.12_env/bin/python' '/home/esp32/esp/esp-idf/tools/idf.py' '-p' '/dev/ttyACM0'"...
--- esp-idf-monitor 1.4.0 on /dev/ttyACM0 115200 ---
I (112) esp_image: segment 1: paddr=00028858 vaddr=408000mationESP-ROM:esp32c6-20220919
Build:Sep 19 2022
rst:0x15 (USB_UART_HPSYS),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x400294ae
0x400294ae: uart_hal_get_txfifo_count in ROM
SPIWP:0xee
mode:DIO, clock div:2
load:0x40875720,len:0x1804
load:0x4086c110,len:0xe2c
load:0x4086e610,len:0x2e70
entry 0x4086c11a
I (23) boot: ESP-IDF v5.3 2nd stage bootloader
I (23) boot: compile time Sep 24 2024 15:49:55
I (24) boot: chip revision: v0.0
I (25) boot.esp32c6: SPI Speed : 80MHz
I (30) boot.esp32c6: SPI Mode : DIO
I (35) boot.esp32c6: SPI Flash Size : 2MB
I (40) boot: Enabling RNG early entropy source...
I (45) boot: Partition Table:
I (49) boot: ## Label Usage Type ST Offset Length
I (56) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (63) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (71) boot: 2 factory factory app 00 00 00010000 00100000
I (79) boot: End of partition table
I (83) esp_image: segment 0: paddr=00010020 vaddr=42078020 size=18830h (100400) map
I (112) esp_image: segment 1: paddr=00028858 vaddr=40800000 size=077c0h ( 30656) load
I (120) esp_image: segment 2: paddr=00030020 vaddr=42000020 size=71484h (464004) map
I (217) esp_image: segment 3: paddr=000a14ac vaddr=408077c0 size=0b980h ( 47488) load
I (229) esp_image: segment 4: paddr=000ace34 vaddr=40813140 size=02938h ( 10552) load
I (237) boot: Loaded app from partition at offset 0x10000
I (237) boot: Disabling RNG early entropy source...
I (249) cpu_start: Unicore app
None
I (890) BLE_INIT: Using main XTAL as clock source
I (890) BLE_INIT: ble controller commit:[392c824]
I (890) phy_init: phy_version 310,dde1ba9,Jun 4 2024,16:38:11
I (950) phy: libbtbb version: 04952fd, Jun 4 2024, 16:38:26
I (950) NimBLE_BLE_PRPH: BLE Host Task Started
I (950) NimBLE: Device Address:
I (950) NimBLE: 40:4c:ca:57:d4:92
I (960) NimBLE:
I (960) NimBLE: GAP procedure initiated: extended advertise; instance=0
I (970) uart: queue free spaces: 8
I (970) main_task: Returned from app_main()
case BLE_GAP_EVENT_LINK_ESTABCode: Select all
case BLE_GAP_EVENT_CONNECTto get the example to compile.
Has anyone been able to get the extended advertising running? Am I missing something?
Reagrds
