Problem connecting to MQTT broker
RouseA
Postby RouseA » Tue Oct 08, 2024 2:08 pm
I’m new to MQTT so forgive my ignorance. I have designed a simple interface board around an ESP32-C3-WROOM module, which I have loaded with ESP-AT firmware. The ESP-AT documentation explains all the allowable commands, but in general terms. I cannot manage to access a broker.
I have installed HiveMQ on a laptop and the log shows that it has loaded correctly and started. I can then access it through the HiveMQ dashboard. However, I can’t communicate with it from the ESP32. This is the sequence of commands I’m using:
    WIFI CONNECTED
    WIFI GOT IP
    AT+CWMODE=1
    OK
    AT+CWLAPOPT=1,31
    OK
    AT+CWJAP=“Virgin2.4”,“Wjsh318263”
    WIFI DISCONNECT
    WIFI CONNECTED
    WIFI GOT IP
    OK
    AT+CIPSNTPCFG=1,0,“0.uk.pool.ntp.org”,“1.uk.pool.ntp.org”,“2.uk.pool.ntp.org”
    OK
    +TIME_UPDATED
    AT+MQTTUSERCFG=0,5,“esp32”,“espressif”,“1234567890”,0,0,“mqtt”
    OK
    AT+CIPSTA?
    +CIPSTA:ip:“192.168.0.136”
    +CIPSTA:gateway:“192.168.0.1”
    +CIPSTA:netmask:“255.255.255.0”
    OK
The next step should be to connect, so I need an IP address or a web address. I’m trying initially to access the local HiveMQ broker. However, I tried looking at the router and it doesn’t show HiveMQ as a connected device, so I can’t see an IP address there. I have tried various combinations without success:
    OK
    AT+MQTTCONN=0,“0.0.0.0”,1883,1
    +MQTTDISCONNECTED:0
    ERROR
    AT+MQTTCONN=0,“192.168.3.102”,8883,1
    +MQTTDISCONNECTED:0
    ERROR
    AT+MQTTCONN=0,“192.168.188.20”,1883,0
    +MQTTDISCONNECTED:0
    ERROR
When I succeed in accessing the local broker my next step would be to access a cloud broker. I want to use encryption but can’t find a means to do that other than hard-programming an encryption code into each ESP32 module. Does anyone have any guidance?
Code: Untitled.txt Select all
esp-at
Re: Problem connecting to MQTT broker
Postby esp-at » Wed Oct 09, 2024 11:54 am
maybe you can read following examples first:
- https://docs.espressif.com/projects/esp ... mples.html
- https://docs.espressif.com/projects/esp ... cloud.html
You can use the MQTT broker under https://test.mosquitto.org/ webpage as a test.
RouseA
Postby RouseA » Wed Oct 09, 2024 1:45 pm
Thanks, but these were the examples I was using:
This gives examples using TCP, TLS and WSS. WHich is appropriate for a local MQTT broker? It gives sample code over TCP using
AT+MQTTCONN=0,"192.168.3.102",8883,1
I don't know where the IP address 192.168.3.102 comes from, and it doesn't work in my case. I've tried numerous alternatives without success.
This expects the certificates and keys to be downloaded from AWS and hard-coded into the ESP32 so a device is fixed to a defined broker. I would like to have standard ESP-AT code so devices could be supplied off the shelf and configured by customers. I think this should be possible since other systems don't require anything to be downloaded. For example, WhatsApp uses encryption, but doesn't require th user to download anything first.
esp-at
Postby esp-at » Sat Oct 12, 2024 3:45 am
You should start a MQTT broker firstly, the ip address and port is that your MQTT broker listen to.
you can use AT+SYSMFG command to update certificate and key.
