problem on wake up from deep sleep
d_ferdi
Postby d_ferdi » Thu Oct 10, 2024 9:10 pm
hallo,
i have a big problem if i wake the device up from deep sleep.
i don't know why, but it seems, that the device boots every time to the bootloader for flashing the device. also after the first power up after the deep sleep mode.
i try to reset it sometimes an avery time it boot in the normal program.
but every time it starts after activating deep sleep, the devive boots, but not in the normal program. only after a second reset or power up, the device works again. but i need the deep sleep for powersaving because this device is powered by an accu.
why does the es not boot to normal mode with the flashed program? why is ist started with the bootloader for flashing it?
normaly the device needs 70 mA, after deep sleep, it need 30-35 mA and after the next reset/powerup it needs 70 mA again.
goodby
Inq720
Contact:
Re: problem on wake up from deep sleep
Postby Inq720 » Sat Oct 12, 2024 10:09 am
You'll need to give more information, like which esp8266 you're using - Bare, 01, 07, 12E, 12F, WeMos, NodeMCU... etc. You'll also have to include wiring if not one of the dev boards. Also, showing your source code is necessary. Otherwise, we'd be throwing darts blindfolded. This link is to another forum where I worked with Deep Sleep and finally got it down to 15 micro-amps during sleep, 15 mA when awake (WiFi off) - https://forum.dronebotworkshop.com/esp3 ... s-returns/
slaboure
Postby slaboure » Mon Oct 14, 2024 8:45 am
In order for the device to wake itself, the RST pin must be connected to the D0/GPIO16 pin. However, that connection must be disabled when uploading new code AFAICT. Did you do so? Once it recovers from deep sleep - unlike for light sleep - it will go through a full setup->loop phase much like a full reboot, it doesn't just resume from where it left of in your loop code.
Hasenradball
ESP12-S module with wired wakup after Deep Sleep
Postby Hasenradball » Fri Dec 12, 2025 8:43 am
Dear Espressif Team,
i used ESP12-F module since years without having prolems getting up from deep sleep.
Now I bought some ESP12-S Modules with the same external circuit.
https://esp8266-01-adapter.de/wp-conten ... ter_v2.pdf
But if I test deep sleep the chip does not wake up as normal, it seems if woke up it is in boatloader/flash mode.
This behaviour I did not see in the ESP12-f modules before.
Is this a normal behaviour?
How to solve this?
Here some Screenshot (Baud:115200):
Boot after DeepSleep
Boot after Deepsleep.png (8.77 KiB) Viewed 3129 times
Here some screenshot with RESET Pushed after Wakeup (Baud:74680):
Bootafter depslepwake with RESET pushed after wake
Bootafter DeepSleep with reset pushed.png (33.9 KiB) Viewed 3129 times
Aktually The ESP12-S module cannot be used with deepsleep.
I also checked the wiring does not matter, it musst be an internal issue.
ESP8266_Adapter_v2.pdf
Schematic for ESP Adapter
(258.01 KiB) Downloaded 28 times
