Flash encryption with internal key generation boots with "invalid header"
Lobelois
Postby Lobelois » Wed Oct 09, 2024 2:33 pm
I'm struggling to write for the first time some ESP32-S3 chips with a firmware, bootloader, ... that are configured to use flash encryption in development mode with UART encryption still enabled and internal key generation.
I do quite a basic programming:
- I'm flashing with esptool (write_partition) some partitions in the ESP32-S3 (plain text),
- Then I use idf.py flash so it flashes the bootloader, ota-initial, firmware and partition table.
It reboots, then takes a while to encrypt the flash as expected, during the process I have an error that does not look blocking saying that the second OTA partition is empty:
esp_image: image at 0x410000 has invalid magic byte (nothing flashed here?)
When it finally reboots, it looks like nothing has been encrypted or is badly encrypted:
invalid header: 0x8630e3ac
It works well afterward when I use idf.py encrypted-flash.
I'm using esp-idf 5.2.3 on an ESP32-S3 chip.
Does anyone have any idea of what I'm doing wrong?
Thank you!
harshal
Re: Flash encryption with internal key generation boots with "invalid header"
Postby harshal » Tue Oct 15, 2024 6:22 am
Hello @Lobelois,
Is it possible for you to share your partition table csv?
Lobelois
Postby Lobelois » Wed Oct 16, 2024 8:02 am
Thank your for your answer.
Here is the partition table:
# Name,                      Type, SubType,  Offset,   Size,          Flags
nvs,                         data, nvs,      0x9000,   0x4000,
otadata,                     data, ota,      0xd000,   0x2000,
phy_init,                    data, phy,      0xf000,   0x1000,
ota_0,                       app,  ota_0,    ,         4M,
ota_1,                       app,  ota_1,    ,         4M,
partition1,                  data, nvs,      ,         1M,
partition2,                  data, nvs,      ,         500K,
partition3,                  data, nvs,      ,         2M,
partition4,                  data, nvs,      ,         2M,
partition_key1,              data, nvs_keys, ,         0x1000,        encrypted
efuse_em,                    data, efuse,    ,         0x2000,
partition_key2,              data, nvs_keys, ,         0x1000,        encrypted
partition5,                  data, nvs,      ,         12K,
partition_key3,              data, nvs_keys, ,         0x1000,        encrypted
partition6,                  data, nvs,      ,         128K,
partition7,                  data, nvs,      ,         12K,
storage,                     data, nvs,      ,         18M,           encrypted
I realised that removing the "encrypted" flag from the last partition was solving the problem.
Is it a limitation of the IDF? Should I use "indirect" encryption (using nvs_keys) instead of direct flash encryption for large partitions?
Thank you!
harshal
Postby harshal » Wed Oct 16, 2024 8:58 am
With the "last partition", do you mean the "storage" nvs partition?
Lobelois
Postby Lobelois » Wed Oct 16, 2024 1:30 pm
Indeed, I meant the "storage" partition, sorry.
harshal
Postby harshal » Thu Oct 17, 2024 5:04 am
ESP-IDF does not support a partition of subtype "nvs" to be marked as "encrypted": reference: https://github.com/espressif/esp-idf/bl ... pp#L21-L23.
You could enable the NVS encryption feature for the partition by initializing it using `nvs_flash_secure_init_partition()`.
Lobelois
Postby Lobelois » Thu Oct 17, 2024 8:21 am
Ok, thank you for your support, I misunderstood the feature.
Users browsing this forum: Bing [Bot], Qwantbot, Semrush [Bot] and 21 guests
