C:/Users/user/Desktop/lcd/main/spi_master_example_main.c: In function 'display_pretty_colors':
C:/Users/user/Desktop/lcd/main/spi_master_example_main.c:380:20: error: implicit declaration of function 'spi_bus_dma_memory_alloc' [-Werror=implicit-function-declaration]
380 | lines = spi_bus_dma_memory_alloc(LCD_HOST, 320 * PARALLEL_LINES * sizeof(uint16_t), 0);
C:/Users/user/Desktop/lcd/main/spi_master_example_main.c:380:18: warning: assignment to 'uint16_t *' {aka 'short unsigned int *'} from 'int' makes pointer from integer without a cast [-Wint-conversion]
cc1.exe: some warnings being treated as errors
* The terminal process "c:\Espressif\tools\idf-python\tools\ninja\1.11.1\ninja.exe" terminated with exit code: 1.
Error in basic examples spi_master/lcd
Good afternoon, experts. I have such a problem: I started studying SPI with the basic example proposed in the documentation https://github.com/espre ... aster/lcd . When compiling, such an error comes out, I understand that he swears that the function 'spi_bus_dma_memory_alloc' is not declared, but can I take it? Tell me please.
Re: Error in basic examples spi_master/lcd
Is the example from the same version of ESP-IDF as the one you are compiling it with?
yes, the versions are the sameIs the example from the same version of ESP-IDF as the one you are compiling it with?
v5.3.1 git - https://github.com/espressif/esp-idf/tr ... master/lcdIn that case, what specific version are you using?
That example in that version builds cleanly for me. For what chip are you compiling and do you have any specific changes in the sdkconfig?
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], PerplexityBot, Qwantbot and 1 guest
