ADC legacy vs OneShot
rocotocloc
Postby rocotocloc » Tue Nov 12, 2024 3:04 pm
I have the following code that works perfectly fine to read the raw value from a temperature sensor (LM35DZ):
Code: Untitled.c Select all
#include "driver/adc.h"
void water_probe_temperature_test_legacy(void *pvParameters)
int adc_raw;
ESP_ERROR_CHECK(adc1_config_width(ADC_WIDTH_BIT_9));
while (1)
adc_raw = adc1_get_raw(ADC_CHANNEL_3);
printf("water probe raw data: %d\n", adc_raw);
vTaskDelay(pdMS_TO_TICKS(1000));
This gives something like the following and it reacts properly to temperature changes:
water probe raw data: 289
water probe raw data: 288
water probe raw data: 282
water probe raw data: 278
water probe raw data: 273
water probe raw data: 269
water probe raw data: 265
water probe raw data: 263
water probe raw data: 262
But since I get the following warning when compiling:
#warning "legacy adc driver is deprecated, please migrate to use esp_adc/adc_oneshot.h and esp_adc/adc_continuous.h for oneshot mode and continuous mode drivers respectively"
I am trying to migrate the code so I wrote this:
#include "esp_adc/adc_oneshot.h"
void water_probe_temperature_test_new_driver(void *pvParameters)
int adc_raw;
adc_oneshot_unit_handle_t adc1_handle;
adc_oneshot_unit_init_cfg_t init_config1 = {
.unit_id = ADC_UNIT_1,
ESP_ERROR_CHECK(adc_oneshot_new_unit(&init_config1, &adc1_handle));
adc_oneshot_chan_cfg_t config = {
.bitwidth = ADC_BITWIDTH_9,
ESP_ERROR_CHECK(adc_oneshot_config_channel(adc1_handle, ADC_CHANNEL_3, &config));
while (1)
ESP_ERROR_CHECK(adc_oneshot_read(adc1_handle, ADC_CHANNEL_3, &adc_raw));
ESP_ERROR_CHECK(adc_oneshot_del_unit(adc1_handle));
But the result is always all bits set to 1 (511, since it's 9 bits width):
water probe raw data: 511
I am following this example but I cannot see what's wrong,
Any ideas?
Thank you.
rocotocloc
Re: ADC legacy vs OneShot
Postby rocotocloc » Wed Nov 13, 2024 6:44 am
I reply to myself.
It's related to the attenuation, for some reason the default value is not the same in the legacy and new library.
I have set 12 db attenuation and I am getting exactly the same value with both libraries:
    int adc_raw;
    // SET ATTENUATION
    ESP_ERROR_CHECK(adc1_config_channel_atten(ADC_CHANNEL_3, ADC_ATTEN_DB_12));
    while (1)
    int adc_raw;
        .atten = ADC_ATTEN_DB_12, // SET ATTENUATION
    while (1)
Dbuggz32
Postby Dbuggz32 » Sun Apr 27, 2025 4:37 am
I think this is related to the Attenuation setting, the old code accepted 11db, the new wants 12db.
regards
Users browsing this forum: Baidu [Spider], Google [Bot], Qwantbot, YisouSpider and 2 guests
