mktime exception after update to idf 5.0
luissilva.lfrs
Postby luissilva.lfrs » Sat Dec 17, 2022 12:07 pm
When i update the IDF to version 5.0 i get this exception from mktime, what can it be?
assert failed: xQueueGenericSend queue.c:837 (pxQueue->pcHead != ((void *)0) || pxQueue->u.xSemaphore.xMutexHolder == ((void *)0) || pxQueue->u.xSemaphore.xMutexHolder == xTaskGetCurrentTaskHandle())
Backtrace: 0x40081fae:0x3ffca370 0x400891e1:0x3ffca390 0x4008d2c1:0x3ffca3b0 0x4015865d:0x3ffca4d0 0x400830b1:0x3ffca510 0x40083169:0x3ffca540 0x400831da:0x3ffca560 0x40147615:0x3ffca590 0x40142679:0x3ffca5b0 0x400e13ff:0x3ffca5f0 0x400e203f:0x3ffca650 0x400e20ea:0x3ffca6c0 0x40089635:0x3ffca6e0
0x40081fae: panic_abort at C:/esp/esp-idf/components/esp_system/panic.c:412
0x400891e1: esp_system_abort at C:/esp/esp-idf/components/esp_system/esp_system.c:135
0x4008d2c1: __assert_func at C:/esp/esp-idf/components/newlib/assert.c:78
0x4015865d: xQueueGenericSend at C:/esp/esp-idf/components/freertos/FreeRTOS-Kernel/queue.c:837 (discriminator 8)
0x400830b1: lock_release_generic at C:/esp/esp-idf/components/newlib/locks.c:192
0x40083169: _lock_release at C:/esp/esp-idf/components/newlib/locks.c:198
0x400831da: __retarget_lock_release at C:/esp/esp-idf/components/newlib/locks.c:334
0x40147615: __tz_unlock at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/time/tzlock.c:50
0x40142679: mktime at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/time/mktime.c:272
0x400e13ff: LOG_Calc_Next_Reading_DT at D:/002-DevESP/001-Robin/main/sources/LOG_Logs.c:378
0x400e203f: LOG_Periodic_Logging at D:/002-DevESP/001-Robin/main/sources/LOG_Logs.c:246
0x400e20ea: LOG_Task at D:/002-DevESP/001-Robin/main/sources/LOG_Logs.c:192 (discriminator 1)
0x40089635: vPortTaskWrapper at C:/esp/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:151
Thanks,
Luis
kammutierspule
Re: mktime exception after update to idf 5.0
Postby kammutierspule » Tue Oct 01, 2024 1:18 pm
I had a similar issue, I found that OS must be running while to access this functions.
Eg: tasks can't be suspended while using these functions.
nopnop2002
Contact:
Postby nopnop2002 » Tue Oct 01, 2024 10:25 pm
There's nothing wrong with it.
#include <stdio.h>
#include <inttypes.h>
#include <time.h>
void app_main()
    time_t now;
    struct tm timeinfo;
    /* fill date_time */
    timeinfo.tm_year= 2024 - 1900 ;
    timeinfo.tm_mon = 10 - 1;
    timeinfo.tm_mday = 2;
    timeinfo.tm_hour = 8;
    timeinfo.tm_min = 0;
    timeinfo.tm_sec = 0;
    timeinfo.tm_wday = 1;
    now = mktime(&timeinfo);
$ idf.py --version
ESP-IDF v5.3.1
kammutierspule
Postby kammutierspule » Tue Dec 03, 2024 4:29 pm
void app_main()
Is that app_main running the FreerRTOS or not?
On my case the happened when I suspend all the OS tasks, like a "critical section"
nopnop2002
Contact:
Postby nopnop2002 » Thu Dec 26, 2024 7:24 am
All applications generated by ESP-IDF run under FreeRTOS.
Therefore, if you stop the OS task, the application will fail.
Users browsing this forum: Bing [Bot], PetalBot, Qwantbot, Semrush [Bot] and 3 guests
