I am restarting work on a project that I was working with based on an ESP32-CAM.
I changed PC and had to re-install the arduino system and the ESP board support.
Now, my project does not compile anymore (while it compiles on the old computer when I take it out of storage, but this is not a good solution)...
It seems that the esp API has changed. Could you please help me find how to convert my "old code" to "new code"?
I have 2 set of errors. One around the setup of the LED control
ledcSetup(LED_LEDC_CHANNEL, 5000, 8);
ledcAttachPin(pin, LED_LEDC_CHANNEL);
And one around a HW timer interrupt!
hw_timer_t *timer = timerBegin(0, 80, true); // set timer 0 of 4 to 80 prescaler. No clue on speed...
timerAttachInterrupt(timer, onTimer, true); // attach onTimer to our timer
timerAlarmWrite(timer, 100, true); // timer every 10micros, repeating
timerAlarmEnable(timer); // enable the interrupt
Thanks for your help.
Cyrille
Project does not compile anymore with latest esp32 arduino board support. Can you help?
Re: Project does not compile anymore with latest esp32 arduino board support. Can you help?
HI, you MUST update your CODE, because the API change-
See the LINK:
https://docs.espressif.com/projects/ard ... o_3.0.html
See the LINK:
lbernstone
Migration guide from arduino-esp32 2.x to 3.0
Thanks for the link and info...
Is there a way, in arduino systems, to load previous versions of API/board dev so as not to have this type of issues?
I faced the same problem with another project (on an other board)...
Cyrille
Cyrille
lbernstone
Sure. If you look at the last image in the install doco, you can see there is a drop down box in the board manager to choose the version installed.
srinivasan
One can go to Board Manager Window and select the Board Library DFRobot and change to any version below 3.0.0 and compile the project.
I tried with 2.x.x and the same code worked fine.
