ESP32 Bluetooth Slave-Master Pair Not Connecting to Each Other
joebro391
Postby joebro391 » Wed Dec 04, 2024 5:35 pm
I am attempting to get two ESP32 modules to communicate with one another in a Master-Slave system. I found the following code (credit to MagicBulletPro) and uploaded them to my two ESP32 units:
MASTER:
#include <Arduino.h>
#include <BluetoothSerial.h>
#include <ArduinoJson.h>
// Create a BluetoothSerial object to handle Bluetooth communication
BluetoothSerial SerialBT;
int Cled = 2;
// Define a struct to encapsulate button-related variables
struct Button
  const int pin; // Pin where the button is connected
  int state;     // Current button state
  int lastState; // Last button state
  bool isOn;     // ON/OFF state to represent if the button is toggled
// Initialize an array of Button structs with initial values for multiple buttons
Button buttons[] = {
    {4, 0, 0, false}, // Button 1: connected to pin 4
    {5, 0, 0, false}, // Button 2: connected to pin 5
    {15, 0, 0, false} // Button 3: connected to pin 15
// Calculate the number of buttons in the array
const int numButtons = sizeof(buttons) / sizeof(buttons[0]);
// Function prototype for looping through buttons
void loopThroughButton();
void setup()
  // Initialize serial communication for debugging
  Serial.begin(115200);
  // Set the built-in LED pin as output
  pinMode(Cled, OUTPUT);
  // Set all button pins as input
  for (int i = 0; i < numButtons; i++)
    pinMode(buttons[i].pin, INPUT);
  // Start Bluetooth communication in Master mode with device name "ESP32_Master"
  // Passing 'true' as the second argument enables master mode
  SerialBT.begin("ESP32_Master", true);
  Serial.println("ESP32 Master Bluetooth Serial Started. Discoverable as ESP32_Master.");
  // Attempt to connect to the slave ESP32 device
  while (!SerialBT.connect("ESP32_Slave"))
    Serial.println("Trying to connect to ESP32_Slave...");
    delay(1000); // Wait for 1 second before retrying
  // Once connected, print a confirmation message
  Serial.println("Connected to ESP32_Slave");
  // Turn on the built-in LED to indicate a successful connection
  digitalWrite(Cled, HIGH);
void loop()
  // Check if data is received from the slave device
  if (SerialBT.available())
    // Read the incoming data from the slave device
    String received = SerialBT.readStringUntil('\n');
    Serial.println("Received from Slave: " + received);
  // Call the function to handle button state changes
  delay(50); // Small delay to avoid overwhelming the loop
  // Loop through each button in the array
    // Read the current state of the button
    buttons[i].state = digitalRead(buttons[i].pin);
    // Check if the button state has changed from its last recorded state
    if (buttons[i].state != buttons[i].lastState)
      // If the button state has changed to HIGH, it indicates a button press
      if (buttons[i].state == HIGH)
        // Toggle the ON/OFF state of the button
        buttons[i].isOn = !buttons[i].isOn;
        // Print the current state to the Serial Monitor
        Serial.print("Button on pin ");
        Serial.print(buttons[i].pin);
        Serial.print(": ");
        Serial.println(buttons[i].isOn ? "ON" : "OFF");
        // Create a JSON document to send the button state
        JsonDocument jsonDoc;
        // Add the pin number and its state to the JSON document
        jsonDoc["pin_number"] = buttons[i].pin;
        jsonDoc["pin_status"] = buttons[i].isOn;
        // Serialize the JSON document into a string
        String jsonString;
        serializeJson(jsonDoc, jsonString);
        // Send the JSON string to the slave device via Bluetooth
        SerialBT.println(jsonString);
      // Small delay to debounce the button press
      delay(50);
    // Update the last state of the button for the next loop iteration
    buttons[i].lastState = buttons[i].state;
SLAVE:
int Cled = 2;
void setup()
  // Initialize serial communication at 115200 baud rate for debugging
  // Start Bluetooth communication and set the device name to "ESP32_Slave"
  SerialBT.begin("ESP32_Slave");
  Serial.println("ESP32 Slave Bluetooth Serial Started. Waiting for Master to connect...");
  // Wait until the ESP32 Master device connects to this ESP32 Slave
  while (!SerialBT.connected())
    delay(1000);  // Wait for 1 second before checking again
    Serial.println("Waiting for ESP32_Master to be connected...");
  Serial.println("Connected to ESP32_Master");
void loop()
  // Check if data is received from the master device via Bluetooth
    // Read the incoming data as a string
    String incomingData = SerialBT.readString();
    Serial.print("Received JSON: ");
    Serial.println(incomingData);
    // Create a JSON document to hold the parsed data
    JsonDocument jsonDoc; // Adjust the size as needed
    // Attempt to deserialize the JSON data from the incoming string
    DeserializationError error = deserializeJson(jsonDoc, incomingData);
    // Check if deserialization was successful
    if (error)
      Serial.print("JSON Deserialization failed: ");
      Serial.println(error.c_str());  // Print the error message
      return;  // Exit the loop if there's an error
    // Extract the pin number and status from the JSON document
    int pin_number = jsonDoc["pin_number"];
    bool pin_status = jsonDoc["pin_status"];
    // Set the specified pin as output
    pinMode(pin_number, OUTPUT);
    // Write the received status to the specified pin (HIGH or LOW)
    digitalWrite(pin_number, pin_status);
    // Send a confirmation back to the master device
    SerialBT.println("Command executed successfully");
**The ONLY change that I made, was I changed references to "BUILTIN_LED" to "Cled", as the "BUILTIN_LED" comes back with an undefined error. (Any chance my boards just suck?). These are the ones: https://www.amazon.com/Teyleten-Robot-E ... 266&sr=8-4
I programmed these ESP32's in my Arduino IDE, and have selected the "ESP32 Dev Module" as the board.
The code compiles and uploads and is running. I can see that both devices are broadcasting, as I can see them on my smartphone as available devices. "ESP32_Slave" and "ESP32_Master" respectively, however, they never connect.
Upon opening the serial terminals, the Slave just prints "Waiting for ESP32_Master to be connected..." and the Master just prints "Trying to connect to ESP32_Slave...", which is as expected. They just never connect.
Any ideas?
I've done Bluetooth systems before with Arduino, with those HC-05 & HC-06 modules and I seem to remember having to pair the modules with AT commands, but have found nothing about that with ESP32's. I'm a little stumped.
Thank you all for any help,
Joe
joebro391
Re: ESP32 Bluetooth Slave-Master Pair Not Connecting to Each Other
Postby joebro391 » Fri Dec 27, 2024 2:44 pm
Any ideas?
This still has me stumped :/
lbernstone
Postby lbernstone » Sat Dec 28, 2024 9:50 pm
Recommendation- don't use BT classic, use BLE
https://randomnerdtutorials.com/esp32-b ... er-client/
Users browsing this forum: Perplexity-User, PerplexityBot and 2 guests
