RobotDragon0
Postby RobotDragon0 » Wed Dec 25, 2024 9:41 pm
ESP32 Development board: ESP32-DEVKITC-32UE
ESP32 JTAG Debugger: ESP-Prog
Hello.
I ran the command
 openocd -f scripts/tcl/interface/ftdi/esp32_devkitj_v1.cfg -f scripts/tcl/board/esp-wroom-32.cfg
to interface with my ESP32 using my ESP-Prog. I got the following error messages. The output on my logic analyzer (https://imgur.com/a/fZIqlKi) shows that TDO is always high, so I am guessing that the error is saying that the MCU is returning logic 1 constantly on the TDO line.
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
Warn : Transport "jtag" was already selected
force hard breakpoints
Info : clock speed 500 kHz
Error: Unexpected OCD_ID = ffffffff
Warn : target esp32.cpu0 examination failed
Warn : target esp32.cpu1 examination failed
Info : starting gdb server for esp32.cpu0 on 3333
When searching for solutions, people mention that this is likely due to a connection issue, but I have checked my connections and they seem correct. I used a different development board and got the same error.
The following are my .cfg files for OpenOCD. What should I consider when debugging this issue?
Thanks.
# SPDX-License-Identifier: GPL-2.0-or-later
# Driver for the FT2232H JTAG chip on the Espressif DevkitJ board
# (and most other FT2232H and FT232H based boards)
adapter driver ftdi
ftdi vid_pid 0x0403 0x6010 0x0403 0x6014
# interface 1 is the uart
ftdi channel 0
# TCK, TDI, TDO, TMS: ADBUS0-3
# LEDs: ACBUS4-7
ftdi layout_init 0x0008 0xf00b
ftdi layout_signal LED -data 0x1000
ftdi layout_signal LED2 -data 0x2000
ftdi layout_signal LED3 -data 0x4000
ftdi layout_signal LED4 -data 0x8000
# Actually this should be in board config file, but we need this for board config detecting script to work.
# That script runs OpenOCD with interface config file only, in that case FTDI
# driver complains that transport is not selected
transport select jtag
# ESP32 series chips do not have a TRST input, and the SRST line is connected to the EN pin.
# The target code doesn't handle SRST reset properly yet, so this is commented out:
# ftdi layout_signal nSRST -oe 0x0020
# reset_config srst_only
# The speed of the JTAG interface, in kHz. If you get DSR/DIR errors (and they
# do not relate to OpenOCD trying to read from a memory range without physical
# memory being present there), you can try lowering this.
# On DevKit-J, this can go as high as 20MHz if CPU frequency is 80MHz, or 26MHz
# if CPU frequency is 160MHz or 240MHz.
adapter speed 500
esp-wroom-32.cfg
echo "WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release."
set ESP32_FLASH_VOLTAGE 3.3
source [find target/esp32.cfg]
Edit:
This post says to reflash using UART and then try using JTAG. I was able to successfully flash the Blink.cpp example from platformio using UART, but when I try JTAG again, I get the same error.
Users browsing this forum: Google [Bot] and 2 guests
