Reading from USB port on ESP32-S3
BivvyCoder
Postby BivvyCoder » Thu Dec 26, 2024 7:48 pm
I'm feeling particularly dumb...
Working on a project with an ESP32-S3-WROOM with built in USB port. I'm using the USB port to program the ESP32 and monitor / debug the code.
When the device first boots I need to write some basic parameters to it - these are device specific, so not hard coded.
My plan was to use the serial monitor in VS Code (or a python script) to write these parameters into the device.
I'd also like to install a device specific private key
I've been looking at the different USB/UART examples in the IDF - tiny USB seems like overkill for this simple application.
In the main application, printf is directed to the USB output and is visible in the debug / serial console in VS Code - so stdout goes to the USB port.
On this basis, I was hoping to use stdin to read from the USB port. Simple...
However the following very basic code does not appear to be work. When I send some text from the computer to the USB port it's not being picked up by the code.
Any suggestions very much appreciated.
/* USB stdin/stdout */
#include <stdio.h>
#include "freertos/task.h"
#include "driver/gpio.h"
#include "esp_log.h"
#include "sdkconfig.h"
void read_stdin_task(void *pvParameters) {
    char buffer[100];
    while (1) {
        printf("Enter some text: \n");
        if (fgets(buffer, sizeof(buffer), stdin) != NULL) {
            printf("You entered: %s\n", buffer);
        vTaskDelay(pdMS_TO_TICKS(1000));  // Delay to avoid busy looping
void app_main(void)
    xTaskCreate(read_stdin_task, "read_stdin_task", 4096, NULL, 5, NULL);
    while (1) {
MicroController
Re: Reading from USB port on ESP32-S3
Postby MicroController » Thu Dec 26, 2024 10:17 pm
BivvyCoder
Postby BivvyCoder » Fri Dec 27, 2024 10:15 pm
Thanks.
Used the code from the link + a bit more research to develop the following which works a treat
#include <stdio.h>
#include "esp_system.h"
#include "string.h"
#include "driver/usb_serial_jtag.h"
#define BUF_SIZE (1024)
#define ECHO_TASK_STACK_SIZE (4096)
static void read_usb_serial(void *arg)
    // Configure USB SERIAL JTAG
    usb_serial_jtag_driver_config_t usb_serial_jtag_config = {
        .rx_buffer_size = BUF_SIZE,
        .tx_buffer_size = BUF_SIZE,
    ESP_ERROR_CHECK(usb_serial_jtag_driver_install(&usb_serial_jtag_config));
    ESP_LOGI("usb_serial_jtag echo", "USB_SERIAL_JTAG init done");
    // Configure a temporary buffer for the incoming data
    uint8_t *data = (uint8_t *) malloc(BUF_SIZE);
    if (data == NULL) {
        ESP_LOGE("usb_serial_jtag echo", "no memory for data");
        return;
    while (1) {
        int len = usb_serial_jtag_read_bytes(data, (BUF_SIZE - 1), 20 / portTICK_PERIOD_MS);
        // Write data back to the USB SERIAL JTAG
        if (len) {
            usb_serial_jtag_write_bytes((const char *) data, len, 20 / portTICK_PERIOD_MS);
            data[len] = '\0';
            ESP_LOG_BUFFER_HEXDUMP("Recv str: ", data, len, ESP_LOG_INFO);
void app_main(void)
    xTaskCreate(read_usb_serial, "USB SERIAL JTAG_echo_task", ECHO_TASK_STACK_SIZE, NULL, 10, NULL);
MicroController
Postby MicroController » Fri Dec 27, 2024 10:45 pm
Thanks for sharing :)
Users browsing this forum: Applebot and 6 guests
