need help : zigbee router mode does not work on esp32-h2
amiral
Postby amiral » Thu Nov 07, 2024 2:53 pm
I developped an iot based on esp32-h2. I have 5 esp32-h2
Network is zigbee
Each esp32-h2 is configured in router mode:
in menuconfig zigbee device type is set to "Zigbee coordinator or router device"
In the code I put:
esp_zb_nwk_device_type_t device_type = esp_zb_get_network_device_role();
switch (device_type) {
case ESP_ZB_DEVICE_TYPE_ROUTER:
ESP_LOGI("ZIGBEE", "Le dispositif est en mode routeur.");
break;
case ESP_ZB_DEVICE_TYPE_COORDINATOR:
ESP_LOGI("ZIGBEE", "Le dispositif est en mode coordinateur.");
break;
case ESP_ZB_DEVICE_TYPE_ED:
ESP_LOGI("ZIGBEE", "Le dispositif est en mode appareil final.");
break;
default:
ESP_LOGI("ZIGBEE", "Type de dispositif inconnu.");
break;
In the console I see "Le dispositif est en mode routeur" (which means my esp32-h2 are ESP_ZB_DEVICE_TYPE_ROUTER)
But the coordinator of the zigbee network displays no neighboors to each of my esp32-h2. I loose frequently some esp32-h2 in my zigbee network although they are placed in chain 4m or 5m one from an other
I do not find any help in the documentation neither in examples, what did I do wrong ?
amiral
Re: need help : zigbee router mode does not work on esp32-h2
Postby amiral » Thu Dec 05, 2024 2:18 pm
I lowered the tw_power of the sonoff coordinator, the zigbee network joins only the nearest esp32 endpoints, not the far esp32. It confirms that the router mode does not work. I think there are bugs in the libraries
tshcherban
Postby tshcherban » Tue Dec 17, 2024 8:25 pm
Hi
Any news here? I'm also interested in this topic
amiral
Postby amiral » Thu Dec 19, 2024 7:22 am
Unfortunately no. I did an upgrade of the esp idf, an upgrade of all librairies, I did not manage to make the router mode work.
Zigbee on esp32 is a bit mistery
vinhquang22
Postby vinhquang22 » Tue Dec 31, 2024 9:27 am
Hi
i am trying to create zigbee mesh through multiple esp32 h2, but i still can't configure the router to extend the network connection range? please can you help me?
amiral
Postby amiral » Tue Dec 31, 2024 3:51 pm
Which version of librairies do you use?
vinhquang22
Postby vinhquang22 » Sat Jan 04, 2025 2:36 am
i use the latest version. I don't know how to set up to be able to transmit data from coordinator to end device via router, can you help me? please :( :(
