Invalid characters on data received from MQTT
JulianMauro
Postby JulianMauro » Sun Jan 05, 2025 11:29 pm
Hi! I have configured an MQTT client (I'm using MQTT V5) on an ESP32-S3 that sends and receives data to/from multiple topics. The chip connects to the Internet via WiFi or LPWA (CAT-M 4G).
However, when receiving data from the different topics, sent from a Java client, the data is received with strange characters at the end of each string. I don't understand why this happens. At first I thought it might be a memory related error, but the invalid characters are always the same, no matter the content or the topic.
Also, as can be seen in the code provided, this invalid-characters-problem also affects the topic. I managed to solve it by removing the last 2 characters before doing the strcmp, however this shouldn't be necessary. Thanks in advance for any help!
Things I try to verify where the error could be:
- Tried with 2 different brokers (we use Cloudflare Pub/Sub but tried with a self-hosted instance. Same error)
- Send a simple message (Same error)
- Use a Python Script instead of the Java Script (Same error)
This is what the ESP32 receives:
[127925 ms] Data: {"time":"2025-01-04T22:52:02.685-03","update":{"version":"1.5","model":"some-model","url":"https://redacted-for-privacy.com/update"}}ÁÄ
‰›¢ˇç®ùÓÖfiÇ¡7y…⁄î9fi⁄lSU™≠€âw
This is the code I am using to both connect to the MQTT Broker and the callback to receive the messages:
Code: Untitled.c Select all
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include "esp_system.h"
#include "esp_event.h"
#include "esp_netif.h"
#include "mqtt_client.h"
#include "esp_crt_bundle.h"
#include "mqtt.h"
#include "log.h"
#define MQTT_CONNECTED_BIT (BIT0)
#define MQTT_FAIL_BIT (BIT1)
#define MAX_RETRY (20)
#define MQTT_UPDATES_TOPIC ("update/esp32")
#define MQTT_CONFIGURATION_TOPIC ("configuration/esp32")
static EventGroupHandle_t event_group;
static esp_mqtt_client_handle_t client;
static int retry_count = 0;
esp_err_t mqtt_connect(mqtt_config_t config);
static void event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data);
esp_err_t err;
event_group = xEventGroupCreate();
esp_mqtt_client_config_t mqtt_configuration = {
.broker = {
.address.uri = config.uri,
.verification.crt_bundle_attach = esp_crt_bundle_attach // Necessary for TLS
.credentials ={
.username= "test",
.client_id= config.clientid,
.authentication.password = config.jwt
.task = {
.stack_size = 12000,
.priority = 16,
.session = {
.protocol_ver = MQTT_PROTOCOL_V_5
client = esp_mqtt_client_init(&mqtt_configuration);
if (client == NULL)
SD_LOG("MQTT Client is NULL");
ASSERT_ON_NULL(client);
esp_mqtt_client_register_event(client, ESP_EVENT_ANY_ID, event_handler, client);
err = esp_mqtt_client_start(client);
if (err != ESP_OK)
return err;
EventBits_t res = xEventGroupWaitBits(event_group, MQTT_CONNECTED_BIT | MQTT_FAIL_BIT, pdFALSE, pdFALSE, portMAX_DELAY);
if ((res & MQTT_CONNECTED_BIT) != 0)
err = ESP_OK;
} else if ((res & MQTT_FAIL_BIT) != 0) {
err = ESP_ERR_TIMEOUT;
return err;
esp_mqtt_event_handle_t event = event_data;
switch ((esp_mqtt_event_id_t)event_id)
case MQTT_EVENT_CONNECTED:
esp_mqtt_client_subscribe(event->client, MQTT_UPDATES_TOPIC, 0);
esp_mqtt_client_subscribe(event->client, MQTT_CONFIGURATION_TOPIC, 0);
retry_count = 0;
xEventGroupSetBits(event_group, MQTT_CONNECTED_BIT);
break;
case MQTT_EVENT_DISCONNECTED:
xEventGroupSetBits(event_group, MQTT_FAIL_BIT);
break;
case MQTT_EVENT_DATA:
int topic_len = strlen(event->topic);
event->topic[topic_len - 2] = '\0'; // This is necessary because the topic contains 2 gibrish characters at the end. Idk why.
if (strcmp(event->topic, MQTT_UPDATES_TOPIC) == 0)
SD_LOG("Topic is updates");
SD_LOG("Data: %s", event->data);
} else if (strcmp(event->topic, MQTT_CONFIGURATION_TOPIC) == 0) {
SD_LOG("Topic is configuration");
break;
case MQTT_EVENT_ERROR:
if (event->error_handle->error_type == MQTT_ERROR_TYPE_CONNECTION_REFUSED)
SD_LOG("Cannot connect to MQTT. Error: %s", mqtt_connection_return_code_error[event->error_handle->connect_return_code]);
break;
default:
break;
chegewara
Re: Invalid characters on data received from MQTT
Postby chegewara » Wed Jan 08, 2025 10:52 pm
There is reason it works this way, and you should make use of esp_mqtt_event_handle_t structure values
https://docs.espressif.com/projects/esp ... tt_event_t
You can find in there:
- char *topic
- int topic_len
- char *data
- int data_len
JulianMauro
Postby JulianMauro » Wed Jan 08, 2025 11:08 pm
- char *topic
- int topic_len
- char *data
- int data_len
Hi, thanks for your reply. In the code I attached, it is possible to see that I do use the esp_mqtt_event_handle_t structure. I cast it from event_data and then I access it when needed (event->topic for the topic and event->data for the data received). Still, the error persists.
Regards.
chegewara
Postby chegewara » Wed Jan 08, 2025 11:47 pm
Yes, i saw your code, but you do this in your code which is wrong, because topic and data are not null terminated:
Thats why you have in that structure topic_len and data_len values.
JulianMauro
Postby JulianMauro » Thu Jan 09, 2025 12:10 am
Hi, thanks for the quick response, and thanks for pointing that out. I have modified the code as follows:
event->topic[event->topic_len + 1] = '\0';
event->data[event->data_len + 1] = '\0';
I cannot test it right now but I think that now it should work.
Regards
nopnop2002
Contact:
Postby nopnop2002 » Thu Jan 09, 2025 12:52 am
//int topic_len = strlen(event->topic);
//SD_LOG("Data: %s", event->data);
int topic_len = event->topic_len;
SD_LOG("DATA: %.*s", event->data_len, event->data);
Users browsing this forum: Baidu [Spider], ChatGPT-User, Google [Bot] and 2 guests
