Arduino ide configuration for ESP32C3 with LCD board
brebisson
Postby brebisson » Wed Jan 22, 2025 12:51 pm
I am using one of the ESP32C3 based boards with the build in 0.42" OLED display...
( https://fr.aliexpress.com/item/1005007448048350.html )
But I am unable to get any wifi working. Using the Arduino WiFiClient example, I am able to successfully connect using a "ESP32C3 super mini board" (a board without the LCD), but if I try the same program on the board with the LCD, it does not work...
Does anyone have any idea what I might be missing?
Thanks,
Cyrille
ahsrabrifat
Re: Arduino ide configuration for ESP32C3 with LCD board
Postby ahsrabrifat » Wed Jan 22, 2025 2:57 pm
Please check if there is a pin conflict in your code. I mean, check if any pin used by the LCD board is dedicated to wifi communication.
brebisson
Postby brebisson » Wed Jan 22, 2025 3:48 pm
Which pins are used by the Wifi?
At this point in time, I am using the Arduino Wifi example which does not interract with any HW (other than Wifi), so if there is a conflict, it is not due to me :-(
Note that the exact same code, compiled with the exact same options, when sent to a ESP32C3 super mini board does work...
So I have no clue where to look...
Cyrille
lbernstone
Postby lbernstone » Wed Jan 22, 2025 4:53 pm
Try running the WiFiScan example with core debug level set to verbose. If you aren't seeing any WiFi networks in the scan, then you probably have an interference/power issue.
Users browsing this forum: Google [Bot], PerplexityBot, Qwantbot and 2 guests
