False errors of version 5.4
I upgraded to 5.4 and noticed this oddity: if you close the idf with an open project, then the next time you run it, the compiler goes crazy - it says in the console window that everything is OK, there are no errors, but in the problems window there are a lot of errors, and there are also errors in the program text. But once you close the project, restart the ide, and then reopen the project and compile, everything miraculously becomes OK. Here are some screenshots.
- Снимок экрана 2025-02-07 102910.png (66.02 KiB) Viewed 4431 times
- Снимок экрана 2025-02-07 102925.png (92.79 KiB) Viewed 4431 times
powerbroker
Re: False errors of version 5.4
yeah, it sucks extremely!
btw, which version you've upgraded from - which one is good enough to rollback to?
upd 1:
switching ESP-IDF instances of different versions, as expected, doesn't affect these bullshitty errors in C editor - this is Eclipse plugin issue.
checked plugin releases 3.0, 3.1 and 3.2 - still no success.
upd 2:
looks like the plugin is not fully compatible with Eclipse CDT 2024-12... but Eclipse 2024-09 + plugin 3.0 doesn't show such bullshit.
there is also no such bullshit in Eclipse 2024-09 + plugin 3.2, but updating 3.0 -> 3.2 is really painful
upd 3:
there is no bullshitty errors in Eclipse 2024-09 + plugin 3.2 because language server F@CKS UP on start and simply DOESN'T WORK
if after shamanic dances it finally works, bullshit remains...
well, i had working configuration of Eclipse 2024-09 + plugin 3.0 + old dependencies, and just destroyed it.
F@CK!!!!!!
if it works, DO NOT upgrade it...
upd 1:
upd 2:
upd 3:
F@CK!!!!!!
To be fair, 5.4 added a memory allocation table at the end of compilation, which is good. But I couldn't color the program text the way I want it to. The hints don't work in one editor, and the colors don't change in the other. There is no happiness in life...
powerbroker
i was highly proud myself thinking i'm the only one able to see the epidemic of sloppiness that affects almost every area...There is no happiness in life...
but it turns out that people know about it
