ESP32-C6 RF pin output impedance
kefecik
Postby kefecik » Tue Feb 11, 2025 10:00 pm
Hello there,
I am pretty new to pcb design and rf. I am designing a board with ESP32-C6 QFN40 package.I know that I need to match the impedance to 50 ohms but I can not find the impedance of PIN 1 (ANT) explicitly mentioned anywhere? This is my current board for reference, if you see any obvious mistakes. Image
ahsrabrifat
Re: ESP32-C6 RF pin output impedance
Postby ahsrabrifat » Wed Feb 12, 2025 12:31 pm
Keep in mind that there should be no ground pour or traces under/near the antenna area.
Bryght-Richard
Postby Bryght-Richard » Mon Feb 17, 2025 9:13 pm
Is D2 going to put 11V on the USB connector?
kefecik
Postby kefecik » Tue Feb 25, 2025 4:12 pm
No it will be reverse biased if 12V is connected.
onhai666
Postby onhai666 » Fri Nov 28, 2025 9:02 am
I have recently stumbled on the same mistery. But through analysis i determined the impedance is about 50 + j0 Ohms.
But I havent tested it yet, did you manage to solve your design in some way?
