I developed an adf project on a Windows 11 PC and pushed it up into a repo on github.
Ideally, I want to clone the project on the second machine and compile it. However, the adf installation is in a different location and I had to manuall alter settings.json file. Now the sdkconfig will not open.
Are there any documents that suggest how to set up so I can seamlessly clone and compile on another machine without manually changing the setup files?
If I get this code to compile and make changes gthat I push up to github, then on the other machine I need to edit settings files again?
How to move vscode - adf project to another PC?
