There are very few information available about Esp32 Pico Mini. I want to use it as it is the smallest one I guess.
But developing software for this, encounters problems.
Arduino IDE 2.x ot 1.8x.
Selected board is ESP32 DEV (there is no this pico mini)
The problem is, that I am unable to control regular pwm servos. No esp pin generates PWM signal. They work if I make high/low, but no pwm. Analogwrite works.
I tried almost all servo espservo library without success. I read that esp api changed from 2x to 3x and it caused some library stopped working. I changed api to 2x, but still no pwm signal on gpio.
What can be wrong?
Thanks for help.
Esp32 Pico Mini
lbernstone
Re: Esp32 Pico Mini
I'd recommend you use the mcpwm driver included in esp-idf. It is far more powerful than any of the arduino servo libraries, and will be well documented with examples. This code uses the older (v4.4) driver, which is a bit easier to understand, but functions exactly the same for this purpose. I just tested it on a pico.
#include <driver/mcpwm.h>
#define SERVO_MIN_PULSEWIDTH_US (1000) // Minimum pulse width in microsecond
#define SERVO_MAX_PULSEWIDTH_US (2000) // Maximum pulse width in microsecond
#define SERVO_MAX_DEGREE (90) // Maximum angle in degree upto which servo can rotate
#define SERVO_PULSE_GPIO (21) // GPIO connects to the PWM signal line
uint32_t convert_servo_angle_to_duty_us(int angle)
return (angle + SERVO_MAX_DEGREE) * (SERVO_MAX_PULSEWIDTH_US - SERVO_MIN_PULSEWIDTH_US) / (2 * SERVO_MAX_DEGREE) + SERVO_MIN_PULSEWIDTH_US;
void setup() {
Serial.begin(115200);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, SERVO_PULSE_GPIO);
mcpwm_config_t pwm_config;
pwm_config.frequency = 50;
pwm_config.cmpr_a = 0;
pwm_config.counter_mode = MCPWM_UP_COUNTER;
pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config);
void loop() {
for (int angle = -SERVO_MAX_DEGREE; angle < SERVO_MAX_DEGREE; angle++) {
Serial.printf("Angle of rotation: %d\n", angle);
mcpwm_set_duty_in_us(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A, convert_servo_angle_to_duty_us(angle));
delay(100); //Add delay, since it takes time for servo to rotate, generally 100ms/60degree rotation under 5V power supply
delay(1000);
lbernstone
Re: Esp32 Pico Mini
The ESP32Servo library appears to be working as well.
https://wokwi.com/projects/323706614646309460
Re: Esp32 Pico Mini
I was experimenting and I found, servos work on other gpio, but not on GPIO0. Documents said that PWM output work on every gpio. They work but not on GPIO0. It is ESP32-PICI-MINI-02.
What is the reason, how to solve it?
lbernstone
Re: Esp32 Pico Mini
gpio0 has an internal pullup. It is the programming strapping pin. It is a poor choice for anything other than the button that is ALWAYS attached to it on a dev board. That said, the code above works fine for me with a servo attached on 0.
Re: Esp32 Pico Mini
Yes, the servo works on other ports. But please try if servopin = 0gpio0 has an internal pullup. It is the programming strapping pin. It is a poor choice for anything other than the button that is ALWAYS attached to it on a dev board. That said, the code above works fine for me with a servo attached on 0.
It is not a dev board, so the programming button is not there, only for programming.
