adf克隆失败怎么解决,用github也不行
huangancheng
Postby huangancheng » Tue Feb 25, 2025 2:05 am
>git clone --recursive https://gitee.com/EspressifSystems/esp-adf.git
Cloning into 'esp-adf'...
remote: Enumerating objects: 18796, done.
remote: Counting objects: 100% (85/85), done.
remote: Compressing objects: 100% (78/78), done.
remote: Total 18796 (delta 11), reused 0 (delta 0), pack-reused 18711
Receiving objects: 100% (18796/18796), 140.93 MiB | 4.68 MiB/s, done.
Resolving deltas: 100% (12915/12915), done.
Updating files: 100% (2242/2242), done.
Submodule 'components/esp-adf-libs' (https://github.com/espressif/esp-adf-libs) registered for path 'components/esp-adf-libs'
Submodule 'components/esp-sr' (https://github.com/espressif/esp-sr.git) registered for path 'components/esp-sr'
Submodule 'esp-idf' (https://github.com/espressif/esp-idf) registered for path 'esp-idf'
Cloning into 'D:/Project_code/AI_doll/windows/esp-adf-git/esp-adf/components/esp-adf-libs'...
remote: Enumerating objects: 4339, done.
remote: Counting objects: 100% (19/19), done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 4339 (delta 17), reused 15 (delta 15), pack-reused 4320 (from 2)
Receiving objects: 100% (4339/4339), 675.87 MiB | 2.92 MiB/s, done.
Resolving deltas: 100% (1940/1940), done.
Cloning into 'D:/Project_code/AI_doll/windows/esp-adf-git/esp-adf/components/esp-sr'...
fatal: unable to access 'https://github.com/espressif/esp-sr.git/': Failure when receiving data from the peer
fatal: clone of 'https://github.com/espressif/esp-sr.git' into submodule path 'D:/Project_code/AI_doll/windows/esp-adf-git/esp-adf/components/esp-sr' failed
Failed to clone 'components/esp-sr'. Retry scheduled
Cloning into 'D:/Project_code/AI_doll/windows/esp-adf-git/esp-adf/esp-idf'...
fatal: unable to access 'https://github.com/espressif/esp-idf/': Failed to connect to github.com port 443 after 21048 ms: Couldn't connect to server
fatal: clone of 'https://github.com/espressif/esp-idf' into submodule path 'D:/Project_code/AI_doll/windows/esp-adf-git/esp-adf/esp-idf' failed
Failed to clone 'esp-idf'. Retry scheduled
fatal: unable to access 'https://github.com/espressif/esp-sr.git/': Failed to connect to github.com port 443 after 21055 ms: Couldn't connect to server
Failed to clone 'components/esp-sr' a second time, aborting
D:\Project_code\AI_doll\windows\esp-adf-git>
