I am having a problem connecting Matter and phone. I would like to make a project with Matter, in this I would like to build on the light example. The problem here is that my ESP microcontroller does not want to connect to the wifi. I have shown the result of the terminal below.
setup:
- virtual machine (due to problems with WSL2)
- OS: Ubuntu 22.04 server
- ESP IDF: 5.4
The steps I followed:
- build and flashed my code to my ESP32C6
- open the terminal
- open my google home app
- add a Matter device
- scanned the QR code from the Espressif SDK site
- I get an can't find product on my phone and get the next one in the terminal.
What strikes me especially is the error code 0x0500300F, I did find a few who experienced this. Here they just never give a solution with it, can someone help me to solve this. The endpoints are not a problem, I add them for my application. But normally this does not give the problem. This worked once but after that worked it never again.
Terminal:
I (1593) chip[DMG]: AccessControlCluster: initializing
I (1593) chip[ZCL]: WRITE ERR: ep 0 clus 0x0000_0030 attr 0x0000_0000 not supported
I (1603) chip[ZCL]: Initiating Admin Commissioning cluster.
I (1603) chip[SVR]: Fabric already commissioned. Disabling BLE advertisement
I (1613) chip[IN]: CASE Server enabling CASE session setups
I (1613) chip[SVR]: Joining Multicast groups
I (1623) chip[SVR]: Server Listening...
I (1623) esp_matter_core: Dynamic endpoint 0 added
I (1633) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (1643) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (1653) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (1663) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (1673) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000006's Attribute 0x00004003 is null **********
I (1683) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (1693) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (1703) chip[ZCL]: Endpoint 1 On/off already set to new value
I (1713) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (1723) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (1733) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (1743) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (1753) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (1763) esp_matter_attribute: ********** R : Endpoint 0x0001's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (1773) esp_matter_core: Dynamic endpoint 1 added
I (1783) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (1793) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (1803) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (1813) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (1823) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (1833) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (1843) chip[ZCL]: Boot reason: 1
I (1843) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (1853) chip[ZCL]: Endpoint 2 On/off already set to new value
I (1863) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (1873) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (1883) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (1893) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (1903) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (1913) esp_matter_attribute: ********** R : Endpoint 0x0002's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (1923) esp_matter_core: Dynamic endpoint 2 added
I (1933) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (1943) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (1953) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (1963) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (1973) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (1983) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (1993) chip[ZCL]: Boot reason: 1
I (2003) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2013) chip[ZCL]: Endpoint 3 On/off already set to new value
I (2013) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (2023) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (2033) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (2043) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2063) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (2073) esp_matter_attribute: ********** R : Endpoint 0x0003's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2083) esp_matter_core: Dynamic endpoint 3 added
I (2083) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (2093) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (2103) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (2113) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (2123) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (2133) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2153) chip[ZCL]: Boot reason: 1
I (2153) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2163) chip[ZCL]: Endpoint 4 On/off already set to new value
I (2163) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (2183) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (2193) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (2203) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2213) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (2223) esp_matter_attribute: ********** R : Endpoint 0x0004's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2233) esp_matter_core: Dynamic endpoint 4 added
I (2233) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (2243) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (2263) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (2273) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (2283) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (2293) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2303) chip[ZCL]: Boot reason: 1
I (2303) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2313) chip[ZCL]: Endpoint 5 On/off already set to new value
I (2323) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (2333) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (2343) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (2353) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2363) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (2373) esp_matter_attribute: ********** R : Endpoint 0x0005's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2383) esp_matter_core: Dynamic endpoint 5 added
I (2393) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (2403) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (2413) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (2423) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (2433) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (2443) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2453) chip[ZCL]: Boot reason: 1
I (2453) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2463) chip[ZCL]: Endpoint 6 On/off already set to new value
I (2473) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (2483) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (2493) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (2503) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2513) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (2523) esp_matter_attribute: ********** R : Endpoint 0x0006's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2533) esp_matter_core: Dynamic endpoint 6 added
I (2543) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (2553) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (2563) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (2573) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (2583) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (2593) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2603) chip[ZCL]: Boot reason: 1
I (2613) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2623) chip[ZCL]: Endpoint 7 On/off already set to new value
I (2623) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (2633) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (2643) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (2653) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2673) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (2683) esp_matter_attribute: ********** R : Endpoint 0x0007's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2693) esp_matter_core: Dynamic endpoint 7 added
I (2693) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (2703) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (2713) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (2723) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (2733) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (2743) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2763) chip[ZCL]: Boot reason: 1
I (2763) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2773) chip[ZCL]: Endpoint 8 On/off already set to new value
I (2773) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (2793) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (2803) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (2813) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2823) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (2833) esp_matter_attribute: ********** R : Endpoint 0x0008's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2843) esp_matter_core: Dynamic endpoint 8 added
I (2843) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (2853) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (2873) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (2883) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (2893) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (2903) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2913) chip[ZCL]: Boot reason: 1
I (2913) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (2923) chip[ZCL]: Endpoint 9 On/off already set to new value
I (2933) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (2943) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (2953) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (2963) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2973) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (2983) esp_matter_attribute: ********** R : Endpoint 0x0009's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (2993) esp_matter_core: Dynamic endpoint 9 added
I (3003) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (3013) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (3023) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (3033) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (3043) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (3053) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (3063) chip[ZCL]: Boot reason: 1
I (3063) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (3073) chip[ZCL]: Endpoint a On/off already set to new value
I (3083) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (3093) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (3103) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (3113) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (3123) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (3133) esp_matter_attribute: ********** R : Endpoint 0x000A's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (3143) esp_matter_core: Dynamic endpoint 10 added
I (3153) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (3163) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (3173) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (3183) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (3193) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (3203) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (3213) chip[ZCL]: Boot reason: 1
I (3223) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (3233) chip[ZCL]: Endpoint b On/off already set to new value
I (3233) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (3243) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (3253) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (3273) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (3283) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (3293) esp_matter_attribute: ********** R : Endpoint 0x000B's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (3303) esp_matter_core: Dynamic endpoint 11 added
I (3303) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000003's Attribute 0x00000001 is 1 **********
I (3313) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000004's Attribute 0x00000000 is 128 **********
I (3323) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000004's Attribute 0x0000FFFC is 1 **********
I (3333) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000006's Attribute 0x0000FFFC is 1 **********
I (3343) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000006's Attribute 0x00004003 is 0 **********
I (3363) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (3373) chip[ZCL]: Boot reason: 1
I (3373) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000006's Attribute 0x00000000 is 0 **********
I (3383) chip[ZCL]: Endpoint c On/off already set to new value
I (3393) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000008's Attribute 0x00000002 is 1 **********
I (3403) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000008's Attribute 0x00000003 is 254 **********
I (3413) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000008's Attribute 0x0000FFFC is 3 **********
I (3423) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (3433) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000008's Attribute 0x00004000 is 64 **********
I (3443) esp_matter_attribute: ********** R : Endpoint 0x000C's Cluster 0x00000008's Attribute 0x00000000 is 64 **********
I (3453) esp_matter_core: Dynamic endpoint 12 added
E (3463) chip[DL]: Long dispatch time: 1969 ms, for event type 2
I (3463) chip[DL]: WIFI_EVENT_STA_START
W (3463) wifi:Haven't to connect to a suitable AP now!
I (3473) chip[DL]: Attempting to connect WiFi station interface
E (3473) wifi:sta is connecting, return error
E (3483) chip[DL]: esp_wifi_connect() failed: ESP_ERR_WIFI_CONN
I (3483) NimBLE: GAP procedure initiated: stop advertising.
E (3493) esp_matter_core: Cluster cannot be NULL.
E (3493) esp_matter_core: Attribute cannot be NULL
E (3503) app_driver: Color mode not supported
I (3693) main_task: Returned from app_main()
> I (3883) chip[DL]: Posting ESPSystemEvent: Wifi Event with eventId : 5
I (3883) chip[DL]: WIFI_EVENT_STA_DISCONNECTED
I (3883) chip[DL]: WiFi station state change: Connecting -> Connecting_Failed
W (3903) wifi:Haven't to connect to a suitable AP now!
E (3903) chip[DL]: Failed to get configured network when updating network status: Error ESP32:0x0500300F
W (3913) wifi:Haven't to connect to a suitable AP now!
I (3913) chip[DL]: WiFi station state change: Connecting_Failed -> NotConnected
W (3923) wifi:Haven't to connect to a suitable AP now!
E (3923) chip[DL]: Failed to get configured network when updating network status: Error ESP32:0x0500300F
I (3933) chip[DL]: Next WiFi station reconnect in 100 ms
I (3943) chip[DL]: Done driving station state, nothing else to do...
W (4043) wifi:Haven't to connect to a suitable AP now!
I (4043) chip[DL]: Attempting to connect WiFi station interface
I (4043) chip[DL]: WiFi station state change: NotConnected -> Connecting
W (4063) wifi:Haven't to connect to a suitable AP now!
E (4063) chip[DL]: Failed to get configured network when updating network status: Error ESP32:0x0500300F
I (4073) chip[DL]: Done driving station state, nothing else to do...
I (5493) chip[DL]: BLE deinit successful and memory reclaimed
I (5493) app_main: BLE deinitialized and memory reclaimed
I (6453) chip[DL]: Posting ESPSystemEvent: Wifi Event with eventId : 5
I (6453) chip[DL]: WIFI_EVENT_STA_DISCONNECTED
I (6453) chip[DL]: WiFi station state change: Connecting -> Connecting_Failed
W (6463) wifi:Haven't to connect to a suitable AP now!
E (6463) chip[DL]: Failed to get configured network when updating network status: Error ESP32:0x0500300F
W (6473) wifi:Haven't to connect to a suitable AP now!
I (6473) chip[DL]: WiFi station state change: Connecting_Failed -> NotConnected
W (6493) wifi:Haven't to connect to a suitable AP now!
E (6493) chip[DL]: Failed to get configured network when updating network status: Error ESP32:0x0500300F
I (6503) chip[DL]: Next WiFi station reconnect in 100 ms
