Here's the original code.
Code: Untitled.c Select all
uint8_t din = D10;
uint8_t clk = D8;
uint8_t cs = D1;
uint8_t Reset = D0;
void spi_write_data(unsigned char w_data) {
unsigned char i;
for (i = 0; i < 8; i++) {
digitalWrite(clk, LOW);
// If you use an Arduino device with faster processing speed,
// such as ESP32, please add some delay.
// The VFD SPI clock frequency is 0.5MHZ as described in the manual.
if ((w_data & 0x01) == 0x01) {
digitalWrite(din, HIGH);
} else {
digitalWrite(din, LOW);
w_data >>= 1;
digitalWrite(clk, HIGH);
void VFD_cmd(unsigned char command) {
digitalWrite(cs, LOW);
spi_write_data(command);
digitalWrite(cs, HIGH);
delayMicroseconds(5);
void VFD_show(void) {
digitalWrite(cs, LOW); // start transmission
spi_write_data(0xe8); // Open Display Command
digitalWrite(cs, HIGH); // stop transmission
void VFD_init() {
spi_write_data(0xe0);
spi_write_data(0x07); // 8 character display 0x07
// Set the brightness
spi_write_data(0xe4);
spi_write_data(0xff); //0xff max//0x01 min
void VFD_WriteStr(unsigned char x, char *str) {
digitalWrite(cs, LOW); // Start transmission
spi_write_data(0x20 + x); // Starting position of address register
while (*str) {
spi_write_data(*str); // ascii and corresponding character table conversion
str++;
digitalWrite(cs, HIGH); // Stop transmission
VFD_show();
void setup() {
pinMode(clk, OUTPUT);
pinMode(din, OUTPUT);
pinMode(cs, OUTPUT);
pinMode(Reset, OUTPUT);
delayMicroseconds(100);
digitalWrite(Reset, LOW);
digitalWrite(Reset, HIGH);
VFD_init();
void loop() {
VFD_cmd(0xE9); // Full brightness test screen
delay(1000);
VFD_WriteStr(0, "Hello!");
delay(1000);
I'm quite lost to be honest and I would like to have this working in IDF if possible, but not really sure what to check anymore. Seems to me that Arduino might be doing some extra steps and configuration behind the scenes that I'm not aware of. Any suggestions or tips are welcome.
