Automation with App Esp RainMaker
Does the Automation created within the EspRainMaker app work without an internet connection?
Re: Automation with App Esp RainMaker
Rainmaker intends to streamline IoT development (RAD). IoT devices leverage a connection for real-time functionality (WAN/LAN) given this is the general concept of IoT. I haven't dabbled with Rainmaker in a while, but it is a cloud-hosted environment that requires internet connectivity between end points.
Regards,
Eric Gionet P.Tech.(Eng.), CIOTP, SMIEEE
Thank you for your reply. Let me explain my project better.
I developed a board with ESP32, reading a SHT30 Humidity and Temperature sensor. The board also has 2 relays.
I programmed it using the Arduino IDE, reading the sensor and two buttons to activate the relays in the ESPRainMaker APP.
In the EspRainMaker app, I created the automation to turn one of the relays on and off based on humidity. It is working fine. Would this automation be dependent on the Internet?
Users browsing this forum: Baidu [Spider], Barkrowler, Google [Bot], YisouSpider and 1 guest
