ESP32 S3 Wroom-1: TFT_ESPI does not work...
Nils_1
Postby Nils_1 » Sun Mar 16, 2025 2:43 pm
Hi all,
I have an ESP32-S3-Wroom-1 DevKit, but unfortunately, I can't get my LCD to work. No matter what I do, I always see only a white screen. I have adjusted the User_Setup file accordingly:
#define TFT_MISO 37
#define TFT_MOSI 35
#define TFT_SCLK 36
#define TFT_CS   39
#define TFT_DC   4
#define TFT_RST 5
I have already tried the following alternative pin configuration:
#define TFT_MISO 13
#define TFT_MOSI 11
#define TFT_SCLK 12
#define TFT_CS   10
#define TFT_DC   4
#define TFT_RST 5
PS: I also have another DevBoard (ESP Wroom 32), and everything works perfectly there (with another PIN-SETUP).
The Code:
#include <TFT_eSPI.h>
#include <SPI.h>
#include <welcomeScreen.h>
TFT_eSPI tft = TFT_eSPI();
void setup() {
    tft.init();
    tft.setRotation(0);
    //tft.drawBitmap(0,0,epd_bitmap_Screen_Save_Nier_Schaltung,240,320, TFT_BLACK);
void loop() {
  tft.fillScreen(TFT_BLACK);
  tft.pushImage(0,0,240,320,epd_bitmap_1);
My Information pages:
For the Pinning: https://www.luisllamas.es/en/esp32-s3-h ... ls-pinout/
Snickers902
Re: ESP32 S3 Wroom-1: TFT_ESPI does not work...
Postby Snickers902 » Mon Mar 17, 2025 1:52 am
Quick question. Have you recently upgraded your IDE? Last week I did and found out the hard way that the newer version would not recognize the older library. Had to dig through archived HDD's to import stuff manually. Just a thoughtful question.
qheinal
Postby qheinal » Tue Mar 25, 2025 2:23 am
it may sound dumb but have you checked that you connected Reset (RST) and DC to the lcd and mcu. If reset or dc is not connected u will just see a white screen when backlight is on. Reset needs to held High for lcd to work
