I have followed the tutorial for creating a custom at command for the esp-at project as described here:
https://docs.espressif.com/projects/esp ... mands.html
However, whenever I run python build.py build (Yes I'm on windows), it does not even compile the c, header and CMakeLists file. How do I get it recognized? I currently use Hercules to test and send the command to the ESP32-C3 directly.
Cannot compile custom at command code
retrospect
Re: Cannot compile custom at command code
You should add ESP_AT_CMD_SET_INIT_FN(esp_at_custom_cmd_register, 1); into your app_main.
And all your custom files should be added into cmake file of component where this files is placed.
https://docs.espressif.com/projects/esp ... ystem.html
have you set up the environment variables according to:
https://docs.espressif.com/projects/esp ... -variables
if this issue still exists, please provide the full compile logs.
