Is it possible to obtain wifi password after an ESP provisioned using BluFi?
`AT+CWJAP?` doesn't return password, only ssid.
Best regards,
Mesih
ESP-AT Wifi Password Retrival
Re: ESP-AT Wifi Password Retrival
Hi~
Since the password is sensitive data, we do not directly provide the AT command to retrieve it.
If you do need it, you can add the AT command yourself and use the esp_wifi_get_config() interface to obtain the password.
