Interrupt watchdog triggers immediately
dg9ngf
Contact:
Postby dg9ngf » Wed Mar 19, 2025 8:05 pm
I'm having big trouble creating anything useful now. I'm working on updating and extending old code that used to work. The new parts are around UART communications. I cannot get it to start because the code immediately triggers an interrupt watchdog. I have no idea why and where. It happens silently and I only know by asking after the next reboot. There is nothing in the serial console, it simply starts over with the "ets" line.
How can I find out what the problem is? I think I checked all my tasks and timers. I'm not dealing with interrupts directly. All loops have a long delay in them (100 ms) but it needs to go away eventually.
I can locate the bug to starting a task. If I'm not starting it, the app stays there sitting and doing nothing. But also not rebooting all the time. If I start that task, it reboots after a fraction of a second. The task does nothing but write a log message anymore, everything else is commented out.
Maybe this part of the code helps:
void main()
	int helloDelay = 1000;
	ESP_LOGI(TAG, "Sending Hello in %d ms", helloDelay);
	timerHandle = xTimerCreate("hello", pdMS_TO_TICKS(helloDelay), pdFALSE, NULL, sendHello);
	configASSERT(xTimerStart(timerHandle, 0));
	while (true)
		vTaskDelay(pdMS_TO_TICKS(100));
void sendHello(const TimerHandle_t unusedParameters)
	ESP_LOGI(TAG, "sendHello");
Any suggestions? It's really annoying that the thing just reboots without telling me any reason.
I'm using VSCode with PlatformIO and its integrated serial monitor.
MicroController
Re: Interrupt watchdog triggers immediately
Postby MicroController » Thu Mar 20, 2025 7:45 am
You shouldn't vTaskDelay() or block in a (timer) callback, and you cannot block when the callback happens in an ISR.
dg9ngf
Contact:
Postby dg9ngf » Thu Mar 20, 2025 9:38 pm
Right, I must have confused timers and tasks yesterday. Removing all delays from timers has helped. I also noticed that I don't need any delays in tasks that already have waiting function calls, like waiting for UART events or items in a queue. I had added those because I remember that a task with a loop that doesn't delay (or apparently otherwise wait) at some point will be stopped after a few seconds or so. Now these parts work fine!
Users browsing this forum: Bing [Bot], ChatGPT-User, PetalBot and 2 guests
