Hi all.
I've added support for https (ssl) to libesphttpd and I'm looking to solve some errors that are popping up with the latest esp-idf master. I suspect these errors are due to improvements in variable detection in master and are issues in libesphttpd/component.mk
Branch is at https://github.com/chmorgan/libesphttpd ... f_chmorgan
/home/cmorgan/projects/esp-idf/components/libesphttpd/component.mk:44: warning: undefined variable 'Q'
/home/cmorgan/projects/esp-idf/components/libesphttpd/component.mk:45: warning: undefined variable 'Q'
/home/cmorgan/projects/esp-idf/components/libesphttpd/component.mk:45: warning: undefined variable 'USE_HEATSHRINK'
/home/cmorgan/projects/esp-idf/components/libesphttpd/component.mk:45: warning: undefined variable 'GZIP_COMPRESSION'
/home/cmorgan/projects/esp-idf/components/libesphttpd/component.mk:34: warning: undefined variable 'Q'
index.html (102%, none)
wifi/140medley.min.js (100%, none)
wifi/connecting.html (100%, none)
wifi/icons.png (100%, none)
wifi/style.css (100%, none)
wifi/wifi.tpl (100%, none)
websocket/index.html (100%, none)
/home/cmorgan/projects/esp-idf/components/libesphttpd/component.mk:38: warning: undefined variable 'Q'
/home/cmorgan/projects/esp-idf/components/libesphttpd/component.mk:39: warning: undefined variable 'Q'
/home/cmorgan/projects/esp-idf/components/libesphttpd/component.mk:40: warning: undefined variable 'Q'
I'm a bit lost as to where to go from here. I know there is something not quite right in the libesphttpd/component.mk file but I'm not sure where to start. Any ideas?
I can create an example app that contains esp-idf master and adds libesphttpd as a component to make it easier to reproduce these errors if that would be helpful. Let me know if that would be helpful.
Chris
Looking for help with component.mk warnings in libesphttpd
Re: Looking for help with component.mk warnings in libesphttpd
All these warnings are harmless, but the component.mk file needs to be updated to take latest IDF changes into account.
Hi ESP_igrr, would you have any pointers to what changes might have to be made or another file I can borrow from? libesphttpd has more logic in it than most component.mk files and I've tried to find similar examples but still aren't sure how to resolve the issue.All these warnings are harmless, but the component.mk file needs to be updated to take latest IDF changes into account.
1. Usage of undefined variables now triggers warnings, ifdef/ifndef should be used to check variables before usage:
http://esp-idf.readthedocs.io/en/latest ... -variables
2. $(Q) needs to be replaced with $(summary)
(as in https://github.com/espressif/esp-idf/bl ... ct.mk#L359)
This is needed because of two changes:
https://github.com/espressif/esp-idf/co ... 0fa674ecb6
https://github.com/espressif/esp-idf/co ... 72765386ee
Ahh thank you, that is very helpful! Let me nail those and take a look at the ifdef checks and then see what else pops up.
This helped a ton. I was able to fix those issues and additional ones, most of them cleanly even! Thank you again.
Hi everyone,
thanks for your effort to make libesphttpd compatible with ESP32 and SSL/TLS. it is exactly what I need. I added the libesphttpd as component in my esp-idf. it appears no in the menuconfig as new component where I can do the component settings.
But how can I use the library now? Is there an example (like esphttpd for ESP8266) running on ESP-IDF? I was not able to get it running.
any help is very appreciated.
Thank you!
Thank you!
here an example how to use libesphttpd with IDF project
It is based on Spritetm git examples,
the original one's with cat pictures,
with removed warnings and working heatshrink compression
Regards,
Grooves
Regards,
Grooves
- libesphttpd_example.zip
- (253.99 KiB) Downloaded 688 times
Users browsing this forum: PetalBot, Qwantbot and 2 guests
