Hi, I'm trying to compile simple LVGL porting example on IDE v.2.3.4 to upload later on Waveshare ESP32-S3-Touch-LCD-7.
currently installed libraries supplied by waveshare:
ESP32_Display_Panel v0.1.4
ESP32_IO_Expander v0.0.4
lvgl v8.4.0
Any one have seen these compilation errors before and how I can clear them?:
/home/alex/Arduino/libraries/ESP32_Display_Panel/src/lcd/ESP_PanelLcd.cpp:467:2: error: unterminated argument list invoking macro "ESP_PANEL_CHECK_FALSE_RET"
467 | }
/home/alex/Arduino/libraries/ESP32_Display_Panel/src/lcd/ESP_PanelLcd.cpp: In member function 'bool ESP_PanelLcd::attachRefreshFinishCallback(std::function<bool(void*)>, void*)':
/home/alex/Arduino/libraries/ESP32_Display_Panel/src/lcd/ESP_PanelLcd.cpp:298:9: error: 'ESP_PANEL_CHECK_FALSE_RET' was not declared in this scope
298 | ESP_PANEL_CHECK_FALSE_RET((esp_ptr_in_iram(callback), false, "Callback function should be placed in IRAM, add
/home/alex/Arduino/libraries/ESP32_Display_Panel/src/lcd/ESP_PanelLcd.cpp:298:34: error: expected '}' at end of input
/home/alex/Arduino/libraries/ESP32_Display_Panel/src/lcd/ESP_PanelLcd.cpp:297:51: note: to match this '{'
297 | if (bus->getType() == ESP_PANEL_BUS_TYPE_RGB) {
/home/alex/Arduino/libraries/ESP32_Display_Panel/src/lcd/ESP_PanelLcd.cpp:292:1: note: to match this '{'
292 | {
exit status 1
Compilation error: exit status 1
Arduino compilation error
Re: Arduino compilation error
Seems you are using this library, but files name do not match
https://github.com/esp-arduino-libs/ESP32_Display_Panel
Try to re-install library.
From logs you can see that library you are using have some typo
Govardhanan
Were you able to compile the same example, solving the compilation problem?
If yes, what did you do?
Can you help me?
Thanks,
Gova.
Can you help me?
Thanks,
Gova.
Users browsing this forum: Baidu [Spider], ChatGPT-User and 4 guests
